Old 01-12-2012, 06:43 PM   #1
Katrina/10
Katrina/10's Avatar
Got some blocks from Boris
Nice quality 2 inch lowering block kit with U bolts. I think it will work well.
http://
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 01-12-2012, 08:28 PM   #2
Zoomin
Man of Mini-Talents
Zoomin's Avatar
Re: Got some blocks from Boris
How long did it take to do the install?
Zoomin is offline   Reply With Quote
Old 01-12-2012, 08:34 PM   #3
Katrina/10
Katrina/10's Avatar
Only about an hour, even did some cleaning and painting while I was at it. Fortunately the old U-bolts came off with an impact.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-12-2012, 08:43 PM   #4
trkfrk
trkfrk's Avatar
There nice! really clean..
Mark
1972 C10 SWB LS1/T56 6 speed trans/4:56 posi with 5.5"-7" static drop/Boss 338 Wheels 18"x20"
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=424609.
My first start up http://youtu.be/R899YQ1OcjU
trkfrk is offline   Reply With Quote
Old 01-12-2012, 08:51 PM   #5
Zoomin
Man of Mini-Talents
Zoomin's Avatar
What are the advantages of doing this vs changing the springs out? I guess the panhard rod doesn't need to be changed.
Old 01-12-2012, 08:52 PM   #6
Katrina/10
Katrina/10's Avatar
Thanks, I thought it would be a good way to lower the truck a little bit, simple and cheap.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 01-12-2012, 08:56 PM   #7
Katrina/10
Katrina/10's Avatar
Advantages: Easy installation, no need to remove springs, low cost, truck keeps original load capacity, just a little less suspension travel. I measured the centering of the axle before and after, and it made almost no change, so no need to mess with the track bar.
Disadvantage, U-bolts and trailing arms are closer to the ground.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
