69 C-10 Front side marker- Do they Flash?
I have a 69 C-10 and my question is- do the front marker lights in the fender flash when you put on the turn signal. I have one side flashes but the other does not. I changed the bulbs but no help. How do I fix this?
1952 Chevy 3100 1969 Chevy C10 2006 Chevy 1500 |
![]() Join Date: Sep 2010
Re: 69 C-10 Front side marker- Do they Flash?
no they do not
I thought in 69 they were just reflectors with no lights. And 70 up were park lights. But either way they don't flash.
1968 chevy lwb, getting ready to join forces with the 70 gmc 1970 gmc swb, getting ready to be a 68 chevy swb 1971 gmc lwb 2500 2wd Sierra Grande 1988 chevy 1-ton crew cab 2wd waiting for a 12v cummins |
All my side markers light up and the right front flashes when i put on the right turn signal. Do I have a short or something? Where do I start looking to fix this???? Thanks for any info, this is strange!
It's probably a ground problem. I'd start by pulling the light and cleaning the ground or running another ground to see if that helps.
Florida Edition
![]() ![]() Join Date: Oct 2010
Start at the right front turn signal and see if it is wired to the side marker light. I bet it is.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
Vintage 4x4s
Probably be better if they both flashed. More of a modern safety feature for lane changes.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ![]() 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
Florida Edition
Thats really not a bad idea at all.
The front side markers flash with the turn signals on my 72, but the rears don't. 69 must be different though. It kind of bugs me that the rears don't flash, doesn't look right to me! I'm thinking about trying to re-wire them so they do. Joseph
1970 Chevelle Nomad station wagon 1966 C-10 lwb,250-six,granny 4speed ![]() ![]() 1966 C-10 lwb,factory A/C,Custom Cab ![]() 1954 Delray 2-door sedan [rat rod project]
![]() Join Date: Mar 2003
If you wire the rears to flash, be ready for the lights to come on when you step on the brakes also
Location: Formerly MD and San Diego, now loving life in Arizona
My '69 Chevy has just reflectors installed front and rear. Before I install my new engine next month I am going to add the wiring needed to install lights at all 4 locations and have them flash as well. The huge amounts of conjested traffic in my area almost requires it for safety reasons.
AL '69 GMC 2500 Custom Camper '69 Chevy C10 396 Last edited by alsriv2; 01-13-2012 at 04:21 PM. Reason: misspelling |
#13 |
#14 |
Will do! Thanks!
#15 |
18 Till I Die
I believe that in 69 they were reflectors( mine were)might have been optional for lighted side markers? When they went to lighted side markers the fronts flashed but the rears do not. With no headlights or park lights on the fronts flash at the same time. With the headlights on they alternate flash. The rears just light up with no changes. If you want the rears to flash its just a matter of where you ground it.
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
#16 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Has anyone checked the wiring schematic? I'm almost positive it shows lighted front side markers. My '69 C20 has lighted front and rear side markers. They do not flash with the turn signals.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#17 |
![]() Join Date: May 2010
My 1969 CST/20 came from the factory with reflectors. I was told it was made in early Dec. 1968. It also did not come with some of the other items that were standard on CSTs later in the year such as a headliner, cargo light and bright trim on the reflectors. The markers may have been changed to lights later in the year. I believe lighted markers were a requirement starting with the 1970 model year trucks. Below is a link to a GM document dated April 1, 1969, for the 1969 Chevy Trucks. If you look at the 8th and 9th pages for C10s and K10s there is a section that shows "Lights and Reflectors" and lists "side marker reflectors as standard equipment". The 12th page showing options lists "bright side marker reflectors" as part of the CST package. This same data is repeated throughout the document for 20s, 30s Suburbans and Blazers. I always thought all the deluxe (bright trim) markers were lighted. Has anyone ever seen any of the deluxe markers that did not have a bulb socket?
The link: http://gmheritagecenter.com/gm-herit...olet-Truck.pdf Last edited by FirstOwner69; 01-15-2012 at 02:12 AM. |
#18 |
here is the wiring diagram. They should light, but not blink.
http://outintheshop.com/faq/wiring/wiring.htm |
#19 | |
1969 c-10 Step Side Long Bed. I-6 250cid = ![]() |
#20 |
![]() ![]() Join Date: Jul 2002
Prior to 1970, side marker light were optional. After 70 they were all lighted. I do not remember if they were tied into the turn signals or not. I don't think they were that way until the square body years.
#21 |
![]() Join Date: Mar 2011
#22 |
When I completed my 71 and started to shake down the electrical system I was surprised by front markers blinking. I thought I had a short! or miss wired them. but the harness was original as was the turn switch . stock GM, functioning per design! cheers, Pat
#23 |
Roadtrip!
![]() Join Date: Feb 2003
I hardly ever see any that flash. My guess is they werent supposed to.
Firstowner69, i have a set of 69 CST side markers with no light provision. Mine is also an early 69.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#24 |
Its more wire, but if you wire the rear side markers up to the front side markers, then there would be no brake interaction.
![]() ![]() 71 C-10 - 307 - 3 on tree 01 Ford Explorer 5.0 v8 96 Mercury Cougar v8 79 Trans Am 403 Olds |
#25 |
Thanks for the reply. Are yours just the plain Jane reflector type markers or are they the deluxe version with the stainless trim? I've never seen the deluxe version without the provision for lights.
