Ad frame boxing question
What did you do with the cross member under the back of the cab?
Thanks in advance Mark |
Re: Ad frame boxing question
well,I removed the old rusted factory cross member and fabbed up one out of 2 inch square tubbing ,pretty stout too,I welded it in first then boxed whole frame.
#3 | |
By the way nice truck sounds good too. Mark |
If the crossmembers are good most guys just box up to them. That is on almost any frame that gets boxed be it 32 Ford or AD Chevy truck.
That would be easier. I was looking at it today and it is solid so maybe I can tie into it on both ends. The frame surprisingly square now so I am leery of removing that cross member because of the cross bracing the gusseting has!
they make a frame boxing kit ? or is it just gettong some plates and going to town on welding .i love free shipping on internet shopping ,,hahaaa
I removed the old cross member but we went with a Progressive cross member. I have a few pictures on my build thread.
Bernie |
#8 | |
Those are nice!
I removed the OE cross member. I have pics on my build thread showing the box plates I made.
My build project http://67-72chevytrucks.com/vboard/s...=1#post4158671 |
#11 | |
After I saw what you did. I thought about using one on mine.But I ended up going with the 76 Monty Carlo triangulated 4 link that I started to use. |
My original plans were to build a triangulated four link set up. You will have a good handling set up and no wheel hop as an added benefit. Keep us posted with photos of your set up.
#13 |
I guess I should start a build thread.
#14 |
yep, about dang time...
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#15 |
I started to do one several times but with the weather being so good i just had to be outside. it,s starting to rain now so maybe I will have time.
