01-12-2012, 09:49 PM | #1 |
side exhaust exit!
looking to do this on my 84c10 step, anyone got photos with it or opinions!
01-12-2012, 11:29 PM | #2 |
yeller
Re: side exhaust exit!
Its going to date your truck back to the 70's, but its your truck and YOU have to like it.
I think if its tastefully done, it could look kind of cool.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale |
01-13-2012, 02:39 AM | #3 |
78 Big10 454
Definitely a "retro" look. I had side pipes on my 78 for years until my wife nagged me to remove them. Can't count how many times she got her legs a little too close to the hot pipes!
1978 Chevy SWB C-10 2WD 454/400 |
01-13-2012, 03:10 AM | #4 |
If done right it looks awesome but you do have to be aware when you exit the truck, burns before you can react! But you know its a live and learn situation. I have learned therefore I don't get burned anymore.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
01-13-2012, 04:02 AM | #5 |
^ that actually looks pretty cool! i would tuck it back a couple inched though, just so the stupids dont step on it
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
01-13-2012, 10:50 PM | #6 |
It is actually tucked in pretty good and you would have a hard time stepping on it. This is a video that shows how it sounds too.
01-14-2012, 02:09 AM | #7 |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
01-14-2012, 02:53 PM | #8 |
i thought this would have been a tuff one to pull off but it looks great on your truck Mike. I really like the wheels and tires your running, what are the specs on those if you dont mind?
01-14-2012, 02:59 PM | #9 |
not something I would do, but it looks pretty cool...
I drive a lowered Chevy, a lifted Ford and I have a 62 VW bug stripped down in the garage.
Which "Piss on" sticker do I buy? Last edited by vegas80step; 02-02-2012 at 10:46 PM. |
01-14-2012, 10:31 PM | #10 | |
01-14-2012, 11:47 PM | #11 | |
http://67-72chevytrucks.com/vboard/c...lverado&cat=13 I didn't build it, so I cant give any advice or tips, but it sure sounds SWEET! She's got a mean motor too!
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
01-15-2012, 02:26 AM | #12 |
This is my set up I like how it blows tire smoke!!!!!
1981 K-5 Blazer 2wd 1985 C-10 Short step 1988 C-10 Suburban |
01-15-2012, 12:46 PM | #13 |
Parts and more parts
I ran a set of side exhausts on oneof my cars, years ago---my ears are still ringing. The sound was too much, even at a young age. I like a good exhaust sound, but I really like it at the rear of my vehicles. I also do not like an exhaust that turns down under your car or truck. It jsut blows too much dirt up in the air.
Headers, crossover, good mufflers ( I lkie the Magnaflow muffs), 2 1/2" dual exhaust pipes, stainless steel tips (no rusting) would be my choice
Frank |
01-15-2012, 12:58 PM | #14 | |
01-15-2012, 03:39 PM | #15 |
http://67-72chevytrucks.com/vboard/s...276897&page=17
Mine, it exits under the steps before the rear wheels. I don't drive it far or much but, it sounds awesome. Dual 3" with 40 series flowmasters. Its not quiet but I don't care. Sounded good with my .060 over 350. Should sound real good with my new 496 when its in.
1987 R10 Pump Gas 496/TH375 Best 1/4 pass to date 60' 1.49 1/4 10.93 MPH 120 |
01-15-2012, 03:46 PM | #16 |
I almost forgot. I used dynomax mandrel bent 45 degree elbows. I just cut and welded them together. It tucked up real nice and it looks good. I also had to make a custom dual hump trans crossmember. I just bought another one from a junk yard and made one from the two. The one that I bought, must have been a recall or update as, it had a spot welded plate on the bottom. I just got 1/8" plate and cut and welded it to the croosmember. I welded all of the seams on both halves. If needed, send me a PM and I'll take some pics.
Dave
01-15-2012, 03:48 PM | #17 |
Side pipes and Side Exit exhaust are different. So I think he means side exit in front of the rear wheels. And yes it looks pretty good.
Matt |
01-15-2012, 07:39 PM | #18 |
I love the look of side pipes and side exit exhaust, and I love the sound as long as good mufflers are being used. The biggest problem I have is that you can't run a side exhaust vehicle in a garage without filling it with exhaust fumes. That makes it a real pain to warm your car up in the garage in the morning or do work that requires the engine to be running. With a rear exit exhaust I can run the engine as long as I leave the garage door open.
02-02-2012, 11:28 AM | #19 |
opps
02-02-2012, 12:27 PM | #20 | |
'87 R30 Crew Cab Dually It's 11 PM, do you know where your IAC pintle is? |
02-02-2012, 02:12 PM | #21 |
Here is my version of side pipe exhaust, a little tough to see because it is black but if you look close you will spot it.
"WIDER IS BETTER" (TRUCKS ONLY) |
02-02-2012, 03:07 PM | #22 |
Sick!!!
02-02-2012, 07:51 PM | #23 |
Badass
With tips coming from right before the rear tires how do you do it if the gas tank is right there?
Think outside the box? -84c10 (1stcar)→My Build← -00 Saturn 5spd drop a gear and disappear! 1/4:13:90 |
02-02-2012, 08:05 PM | #24 |
I don't believe the gas tanks hangs down lower than the body so you would just run the pipe right under the tank. Of course with a longbed you could run the pipe just passed the tank and out a hole in the side of the bed.. like this.
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
02-03-2012, 12:07 PM | #25 |
Well on my stepside, I got rid of the tank because, it would have got in the way of the way I did the exhaust. So, I put a fuel cell in.
