01-12-2012, 11:32 PM | #1 |
Curiosity Killed The Cat
Ever since I discovered the 8.1 Vortec, I have wondered what the differences are between it and a 454 Vortec. I know the stroke is different. Will these bolt in place of a normal 454? Is there a carburated intake manifold that fits them? Will standard BBC heads fit them? In the future I might like to put one in my $100 4X4 beater.
01-13-2012, 12:22 AM | #2 |
My Carbon Footprint
Re: Curiosity Killed The Cat
......and here I thought my left front tire killed the cat!
01-13-2012, 01:33 AM | #3 |
See below
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ Last edited by IGOR; 01-13-2012 at 01:39 AM. |
01-13-2012, 01:38 AM | #4 | |
Yes, they will bolt in place of a normal 454. Dart came out with carb intake last April: http://www.dartheads.com/products/in...-manifold.html Standard BBC heads will not fit. Lots of info in this link:http://coloradok5.com/forums/showthread.php?t=283625
-Ben 1972 CST K5 - Undergoing frame off, 8.1/4L80E/NP205, 3/4 ton, 8" lift, currently a pile of parts that when assembled resemble a Blazer 1972 K10 - Rust Bucket, TBD 1976 C10 SWB, 350 / T350 My blazer build thread: https://ck5.com/forums/builds/72-k5-...17-update.410/ |
01-13-2012, 08:50 AM | #5 |
Did they use a distributor? What would it take to run a normal HEI?
01-13-2012, 12:16 PM | #6 |
No distributor - computer fires coils at proper time.
8.1 is LS based top half (intake, fuel injection, electronic coils on valve covers), and similar to 454 on bottom half - (but has different firing order, different crank, etc) I don't know what it would take to run normal HEI - likely have to figure out if there is worm drive gear on camshaft (which I'm not sure) and work that out with firing order sequence. But - why not keep the electronics? You would be getting rid of one of the key best features of that motor. You can get modified plug & play harnesses most anywhere, and they are cheap - four wire hookup. I've seen them as cheap as $250 up to $900. You can use 8.1 computer to control 4L80e transmission, which is the younger brother to a T400 but with overdrive gear. Or get an Allison and get a big duty transmission with 5 speed & overdrive.
01-15-2012, 10:59 PM | #7 |
The dart intake says it has a hole for the dizzy. The cam might be a problem though.
As for the electronics, I like what I understand. They're probably pretty simple,but there's not much to go wrong with HEI and a carb(except the module of course). |
01-16-2012, 01:50 PM | #8 | ||
"I ain't nobody, dork."
The 8.1's are still pretty popular with the offshore boat racing cats. I would search through some of the websites that pertain to offshore boat racing.
The 8.1 is a kinda bastardized engine and never rally gained much popularity. Hence there is a very limited aftermarket for them. Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
