mono leaf help
I have a 58 3/4 ton and want to lower it with mono leafs. I am changeing the front axel to 1/2 ton. Will 1/2 ton leafs work on the back? Are the spring hangers the same on the rear of the frame? Most places only list 1/2 ton. If i lower it 4" in the front will 4" in the back level it out? I don't want to c notch it, so is 4 as low as i can go. With a flip kit do you have to c notch it? Wow alot of questions from somone who just reads and learns. Thanks john j
you laugh at me cause i'm different ; i laugh at you cause you're the same ![]() |
world class smart ass!
Ok,
1)1/2 ton leafs will work as long as they are the same legnth from mount to mount. 2)Not sure about stock hight for a 58, but the rear is usually 2" taller than the front, so if you want level then a 3-5 would be good, unless you want to notch your frame.. 3) no you don't usually have to notch your frame with just a flip kit, but your truck is probly going to be different then most others, your best bet is to measure the distance from your axle to your frame, that could give you a good guess on how much room you have to work with.... On the 73-87 trucks it is about 5" before you start to think about notching the frame.. Hope this helps.. Have fun.
Aric 75 2WD BLAZER (never ending project) -some day maybe- 02 2500HD CREW CAB 4X (daily drive) -8" lift 37s and 22s- ____ ![]() |
Thanks alot for the info. That gives me what i need to know. john j
