Old 01-13-2012, 11:39 AM   #1
dan42
dan42's Avatar
ANyone know if different spring rates deteriorate handling?
I was wondering if you put 2.5 inch drop spindles with stock springs, and 4" drop springs on the the back, if the handling of the truck is compromised because of the difference between the ride quality of the two. For those of you that have this setup, do you notice anything in terms of ride quality or squirrely handling? Your input would be appreciated.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 01-13-2012, 11:55 AM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: ANyone know if different spring rates deteriorate handling?
Mine seems to be better.Of course that may be because the left front spring came out in 3 pieces.the overall handling should be better due to a lower center of gravity.The ride on mine is some better,though I still need to trim the rear bumstops der to some bottoming on hard bumps.I haven't done the shock relo in the rear yet either.I will also be adding a sway bar.I did new tires and wheels and only drove it a few hundred miles before doing a PS swap so that changed it even more.It did seem better after the suspension work but with new BJ's,tie rod ends.springs,brakes,wheels and tires,I would have been surprised if it didn't.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-13-2012, 12:18 PM   #3
RenoKeene
Florida Edition
RenoKeene's Avatar
I had that setup on my longbed 1/2 ton without a front stabilizer and it handled pretty good and rode soft. That was with a big block and new big block (3/4 ton) springs. Now it's a short bed with 5" drop springs in the back, shock relocator kit, adj track bar, 3/4 ton front stabilizer and a half coil cut off the front springs. Should ride a little stiffer but handle a whole lot better in the turns. You should by happy with what your planning I think.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod
67 C-20 Slant Back Wrecker "Mad Max"
67 C-10 Ratrod "Step-N-Wolf"
71 Serro Scotty Sportsman camper "Scotty"
97 LT1 Z28 "The Hornet"
Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684
Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394
RenoKeene is offline   Reply With Quote
