Active Member
Mr. Gasket #720-6007 2" carb spacer $10.00
I have a Mr. Gasket dual bolt pattern 2" open plenum carb adapter
Excellent condition $10.00 plus the ride I can take pay pal, cash or check If you pay by check please allow enough time for the check to clear the bank
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Re: Mr. Gasket #720-6007 2" carb spacer $10.00
how much to ship to zip 58265?
Active Member
ill let you know
Thanks Bill
Active Member
USPS priority is $7.90
USPS parcel is $7.35 Let me know if that works or not Posted via Mobile Device
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() Last edited by 1968SWBBigBlock; 01-13-2012 at 06:17 PM. |
I will pass thanks.
![]() Join Date: Aug 2009
Can you get me the opening sizes of this adapter?
Posted via Mobile Device |
Active Member
Will do - I will measure it tonight
Can you get a few inside measurement?
Active Member
Not a problem
The 1st thing I need to do is find the spacer I really should not clean things up Posted via Mobile Device
Never mind pass...
