Lizard Skin Spray on Insulation Special
We have seen that some of you where interested in the Spray on Insulation and Spray on Sound Control. So we have decided why not run a special....
Lizard skin products are sold individually or in kits 2 Gal. Sound Control $140.00 ![]() 2 Gal. Ceramic Insulation $155.00 ![]() Superpro Spray Application kit $78.00 ![]() Never cut & paste again--NO GAPS, NO SEAMS, NO SCISSORS, NO SWEAT! Easy spray-on application, environmentally safe, cleans up with soap & water and can be sanded and painted body color if desired. If you have any questions feel free to ask! |
Re: Lizard Skin Spray on Insulation Special
How heavy is this stuff? I am thinking the inside of a Blazer top, would it weigh too much?
how much for the gun/ lizard skin coating ( the one that you think would be best for BOTH climate control, and road noise) WITH shipping to 74011
thanks |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
So you spray one then the other? correct?
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
How much would one gallon cover?
any orther way to spray this.mabe a like under coating gun
What type of prep work should be done? Is it better to use this on the inside or bottom side of cab?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
![]() Join Date: Apr 2008
When I was at one of the shows the guy at the Lizard Skin booth said you can roll it on if you want. Of course it is much easier to spray I would imagine. But this stuff is really cool he had half of a frying pan coated and an ice cube on either side of the pan. The one on the bare frying pan boiled in not too much time at all and the one on the coated side remained frozen for the ten minutes we were talking.
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
#13 |
if the area is sanitary " rust free" a little scotch bright and spray, if there is some surface rust remove scotch bright and spray.... this product is designed to be used on the inside of the cab but we have had a customer spray the enite outside portion of his van LOL
#14 |
#15 |
Blazer definitely 2 gallons
#16 |
Curious if a gallon would do floor, firewall, rear, and misc in a truck cab? Also, unclear if the texture spray gun I already have will lay this stuff down?
www.tomthetruck.blogspot.com <-- Aka build thread. |
#17 |
^^^I am wondering the same thing^^^
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
#18 | |
#19 |
Thanks Ise not so good with the maff stuff.
#20 |
Also, I'll be calling in a month or so. Hoping to get my cab blasted, and the underside and firewall painted by end of this month. This stuff will be going in soon after.
#21 |
Any deal on 2 gallons of Ceramic insulation and the gun shipped 97221?
#22 |
#23 |
How much for 1 gallon of each shipped to 77373? Dont need the gun.
1968 C10 SWB Dropped 5 in tha back 3 in tha front My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902 |
#24 | |
Thank you Last edited by American Pastimes; 03-01-2012 at 02:35 PM. |
#25 |
We still have Lizard Skin on Sale! Please send a PM if you have more questions.
