Old 01-13-2012, 04:38 PM   #1
skip99
skip99's Avatar
one piece window conversion
can someone post a picture of a 47-50 1 pc. window door ,interior side?
I need to see where the parts on the regulator mount in the door. I should be able to tell by the visible screws...thanks
Im converting to 1 pc, I have the regulators..
i considered using the single arm from my 51, and just adding a pivoting arm to carry the longer window, but i notice on the 47 type that there is another channel that welds to the center of the door just below the armrest.
and I would have to cut the tension spring off the 51 style so the window would not hit it, ( is the spring just to help when rolling the window up?
I also plan on using just the bottom of the 47 type window frame, so the glass will fit my 51 channels..
Tami's 51 build
http://67-72chevytrucks.com/vboard/s...d.php?t=428878
skip99 is offline   Reply With Quote
Old 01-13-2012, 07:10 PM   #2
Atomsplitter
Atomsplitter's Avatar
Re: one piece window conversion
Not sure if any of this will help but it's a "How To" guide for 1-Piece Windows.
http://customclassictrucks.automotiv...ion/index.html
Atomsplitter is offline   Reply With Quote
