![]() Join Date: Aug 2011
Help getting a Carb Rebuild kit for my Carb
Guys, here are some pictures of my 1 barrel Rochester that I need a rebuild kit for.
Re: Help getting a Carb Rebuild kit for my Carb
Clean it up, there should be more numbers on it.
I snipped this from an old post on another forum: I can provide some info that may help. I've since switched back to a stock OEM carb but I still have the info in my old book. It may not be the exact same for yours...but many (a wloe bunch) of the carb parts were interchangeable from one Rochester 2 barrel to another...so you should do fine. However, if I remember correctly once you remove your Rochester you should be able to find numbers somewhere on the carb that will give you the correct info to buy a rebuild kit. Any Napa or good parts house should be able to assist. Here is what I have in my old records. 1) Delco Rochester 2G 2 2 barrel 3) Rochester kit # 7012452 or 7009930 4) Jiffy kit # AZ09RAX (that may be A2 and not AZ) And those Rochester #'s just may be the #'s on the carb...don't really remember...but this should help you out. Also, when I bought this carb from Man-a-fre I think they said it was from a '67 or so Chevy/GMC truck. If all else fails, post back up & I think I can locate an old rebuild kit. By the way when I switched back to OEM I was very happy. My Rochester ran really well so I didn't see any real power gains but no loss either. The big benifit was MPG shot up from 9-11 to 12-15....consistently. Long winded...but hope this helps you. |
Hy pvienneau, the Borg Warner p/n for a carb kit for a 1932 - 62 Rochester 1 barrel carb is 10158, hope that helps
OK, the numbers on the 3 sections of the carb are 7003911, 7003913, and 4475. Where can I get the complete rebuild kit? I have it broken down and have all the pieces. I'd like to replace everything. The float included.
Thanks Pat |
Hy Pvienneau, the Borg Warner p/n for the float is CF289B(B), hope that helps.
