Old 01-13-2012, 10:42 PM   #1
corvettejim1968
corvettejim1968's Avatar
help with lowering and disc brakes for a 65
i want to lower my truck and do a disc brake conversion at the same time. i have the 6 lug rally wheels and i want to keep them. i dont need power as im sure it will brake so much better than drum all around. i want to drive this truck all over town and not worry about the speed humps so much. one guy said a 2...4... drop would be good. i want it as low as daily driving will allow. can you help me pick out the good parts for this conversion. thank you.
Hand Made Factory reproduction A/C vents
text or call 602-361-6421
Website for A/C vents
https://coolc10.com/
corvettejim1968 is offline   Reply With Quote
Old 01-13-2012, 10:51 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: help with lowering and disc brakes for a 65
Look at this thread,...
http://67-72chevytrucks.com/vboard/s...d.php?t=427852
Keith
Convert to disc brakes.
Old 01-14-2012, 12:37 AM   #3
protrash64
Resistance is Futile
protrash64's Avatar
Hey, I recognize that one!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-16-2012, 10:34 AM   #4
srziemkowski
srziemkowski's Avatar
If you end up doing 5 lug in the front and the issue is just the wheels,that wheel is available in 5 lug also with the same style cap
srziemkowski is offline   Reply With Quote
Old 01-16-2012, 10:45 AM   #5
waspp
waspp's Avatar
Is there an issue with the 6 lug rallies rubbing on the front when the truck is lowered?
waspp is offline   Reply With Quote
Old 01-16-2012, 10:50 AM   #6
protrash64
protrash64's Avatar
No, but the tires touch the fender. On tight turns; barely. Thats my blue '66 in pic above. I'm running 235/70's all around. Front is lowered about 4.5-5''.....not sure exactly cuz I cut one loop off of 1'' lowering springs.
Old 01-16-2012, 10:58 AM   #7
waspp
waspp's Avatar
Yea I have been reading your other thread, i'm getting ready to buy my front end parts but haven't decided on the amount of drop yet. I do know I will get 2.5 " dropped spindles but not sure if I will go lower. Thanks for the info.
Old 01-16-2012, 11:05 AM   #8
protrash64
protrash64's Avatar
No prob. The only way the rims will get any rub is on the inside if you remove the bumpstop mount from the lower a-arm. This will allow you to crank the wheel until there is contact. This happens on my '64 with 5.25'' of backspace. The ralleys are about center for backspace I believe.
Old 01-16-2012, 11:17 AM   #9
lolife99
lolife99's Avatar
The 6-lug 15x8 ralley wheels have a 3-5/8" backspace.
(5-lug 15x8 wheels have a little more BS at 4")
The super rare 15x7 6-lug ralleys have a 4" backspace which would help with your turning issue.
5-lug ralley wheels are more plentiful and come in 6.5", 7," and 8" widths.
If you could find a 5-lug rearend cheap,... I would consider changing to 5-lug up front.
Keith
Old 01-16-2012, 01:08 PM   #10
protrash64
protrash64's Avatar
I had mentioned on another thread that I thought there was less BS on the 6-lugs compared to my 5-lugs. Never measured; good info lolife. It's also the same BS I see on all the old aluminum slot wheels I see and thought wouldnt fit.
Wonder if the mount surface could be machined down a bit; nearly an inch thick?
Old 01-16-2012, 01:29 PM   #11
waspp
waspp's Avatar
I just ordered a 6 lug 2.5 drop disc brake kit from Brothers, they're running a 15% discount through January. Never bought from them so we shall see.
