Old 01-13-2012, 11:30 PM   #1
bigredchevy
bigredchevy's Avatar
turbo 400
86 chevy cc my coloum shifter won't line up for nothing it goes in park long draw for reverse when it goes in reverse there's no lights but I push it back up some then I get lights but not in gear no more. Neutrel seems to be in the same place reverse is, once you pull down then back up and drive is about down to my knee I've changed the peice on the side of the trans with little fix of it. any thoughts?
1986 chevy 3+3 400 sbc turbo 400
bigredchevy is offline   Reply With Quote
Old 01-14-2012, 02:30 AM   #2
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
Re: turbo 400
1. Block your wheels.
2. Start engine and shift into reverse, when you feel the truck go into reverse, shut off the engine BUT DO NOTSHIFT BACK TO PARK.
3. Neutral safety switch is located on top of steering column near the firewall and is adjustable. Older models were/are held in place with 2 sheet metal screws that have either a 1/4" or 5/16" hex head on them located at either end of the switch. Newer ones simply snap into place and have a slide adjuster built into them that can be easily moved side to side.
4. Identify which style yours is and adjust it to where the reverse lights come on at your desired shifter location. (Note that having some one watch and announce when the reverse lights are on makes it alot easier on your back/knees/temper).
5. Make note of the location of your "PRNDL1" indicator on the dash. Is it lined up with the "R"? if not, it too can be adjusted by removing the lower dash covers under the column and sliding the anchor for the needle around the shroud to line up the needle where you need it to be.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 01-14-2012, 09:41 AM   #3
Hertzdaddy
Re: turbo 400
Don't forget to put it back in park before you start, in case lockout doesn't work.
Hertzdaddy is offline   Reply With Quote
Old 01-14-2012, 04:31 PM   #4
bigredchevy
Re: turbo 400
Thanks Guys ill give it a look when I get off work
