Old 01-13-2012, 11:40 PM   #1
BrookelynnGreen
BrookelynnGreen's Avatar
my front right tire sticks out
On my 86 chevy pickup my right tire stick out about 1/2"-3/4" more than the other 3 tires, what could be the problem?
Its the red truck that is in my profile picture.
-Samuel
"Knowledge Is Power"
BrookelynnGreen is offline   Reply With Quote
Old 01-13-2012, 11:43 PM   #2
cochino12
It followed me home?
cochino12's Avatar
Re: my front right tire sticks out
I've had the same problem with several trucks, different brand spindles... hopefully someone can help
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-14-2012, 07:17 PM   #3
Cheyenne Dan
Cheyenne Dan's Avatar
Mine too, driver's side though...all stock suspension
Cheyenne Dan is offline   Reply With Quote
Old 01-14-2012, 07:26 PM   #4
jitteryguy
GoatLube Experss
jitteryguy's Avatar
I've seen some vehicle's that the body has shift'd on the mount's and it cause's one tire to stick and the other to be tuck'd.
it's somethen to check into. look at the hood seem's and bed to cab gap's, if this the case you should be able to spot it there also.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 01-15-2012, 08:06 PM   #5
cochino12
cochino12's Avatar
Anyone else?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 01-15-2012, 09:33 PM   #6
Cheyenne Dan
It makes sense about the body bushings shifted, my truck was run off in a ditch by the previous owner and it has very little damage to passenger side fender but my truck has a dent on driver's side rear cab on the trim where the bed came into contact with it. Maybe it was snatched out of ditch causing this. I thought about taking it to an alignment shop but my truck drives fine, maybe a frame shop or body shop would be a good idea.
Old 01-17-2012, 08:25 AM   #7
Keith Seymore
Keith Seymore's Avatar
Some were built that way at the factory.
The cab is so short that it can be set crooked on the frame (when viewed from the top). When that happens, the hood shoots off to that same side. The front end is shifted to fit the fenders to the hood.
Normally you can tell because the gap between the front bumper (which is attached directly to the frame) and fender will be greater on one side than the other.
Longer cabs, like crew cabs or Suburbans, are less susceptible to this.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 01-17-2012, 10:22 AM   #8
Desert1957
Desert1957's Avatar
I guess its possible when it was towed out, a hard side pull with a large tow truck could bent both frame rails over slightly.
Should be a little noticeable with all the Fender / hood gaps.
Desert1957 is offline   Reply With Quote
