Old 01-14-2012, 02:49 AM   #1
nickv6266
nickv6266's Avatar
1971 SWB 4x4 drivetrain questions
Just bought a 71 swb 4x4 that has some later model 70s axles under it . Im wanting to put this truck back to 1/2 ton as its not going to be off road much.Im wanting to put this truck back close to original. It now has 14 bolt rear and not sure up front but it is 8 lug. Im not a 4x4 guy im mostly into muscle cars and 68 2wd C10s. What would be the most cost effective way to switch this back to 1/2 ton, Im assuming switch the complete rear back to 12 bolt, Is there anyway to leave the front alone and just put 6 lug rotors? Any advice would be appreciated. Thanks
nickv6266 is offline   Reply With Quote
Old 01-14-2012, 10:17 AM   #2
Re: 1971 SWB 4x4 drivetrain questions
You could switch the knuckles-out,but I think just swapping the whoe axle is the easiest. And,if you want it close to original you'll want a Dana44 if it now has a 10-bot. It could be a Dana44. If you showed pictures we could tell you. I think 1/2t axles are pretty easy to find for not a whole lot of money.
Old 01-14-2012, 10:39 AM   #3
Mike C
Mike C's Avatar
If you are going to run any size tire (Larger than 31's) I would keep the 8 lug axles and their MUCH larger brakes.
But if you are going to get rid of them, know EXACTLY what you have before doing this. You might have a Dana 60 in the front and both axles could have traction enhancing differentials which adds significantly to the value.
A Dana 60/14 Bolt combo with Detroits should be worth $2000 while a pair of 1/2 ton axles MIGHT bring $500. MIGHT.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Mike C is online now   Reply With Quote
Old 01-14-2012, 04:55 PM   #4
nickv6266
nickv6266's Avatar
What would be the best donor front and rear axles to go with for this setup. Ive heard something about welding new perches on for certain axles, Can someone enlighten me on that. Thanks
Old 01-14-2012, 05:39 PM   #5
Mr. 250r
Mr. 250r's Avatar
welding new perches usually goes along with using an axle from a different truck like in my case i used a 2005 full floater and had to move the perches inward 3in on each side i think, or lets say using an old 1 ton full floater under a regular cab 1/2 ton the 1 tons frame is narrower making the spring perches sit closer in on the axle although the axle is still the same width if im correct, hope thats not confusing lol
1987 Chevy V30 - http://67-72chevytrucks.com/vboard/s...d.php?t=573854
1988 IROC-Z Camaro - 305/T5 T-Top
1989 GMC V35 - Marbolo Express http://67-72chevytrucks.com/vboard/s...d.php?t=596850
1991 V2500 Suburban Silverado - Sold
1991 V2500 Suburban Scottsdale - Big Nasty http://67-72chevytrucks.com/vboard/s...d.php?t=497423
2001 Ram 3500 5.9 H.O NV56 EC LB DRW - Sold
2003 1500 Silverado - Selling
2004 Ram 3500 5.9 H.O NV56 CC LB DRW - Sold
2005 Silverado 2500HD 6.6/ZF6 CC LB SRW
Mr. 250r is offline   Reply With Quote
Old 01-15-2012, 01:15 PM   #6
Look for axles from a rotted out 69-72 Blazer,Burb,or truck. I actually have one ('72 Blazer) but am too far away to do you any good. I also just sold my '71 K/10 SWB and I'm pretty sure that guy wasn't interested in the axles. But,again,he's only about 150 miles closer. Wait,that's right,my Blazer is at my mom's right near where he is. Anyway...too far,right?
Old 01-15-2012, 10:21 PM   #7
nickv6266
nickv6266's Avatar
Yeah that is too far. I know of a 72 blazer here in town for sale that is pretty rusty I wonder what axles it would have from factory.
Old 01-16-2012, 08:53 AM   #8
It will have the same axles. If it's an automatic it will have 3.08s and a manual will have 3.73s,unless it lists an optional ratio.
