What is a Integrated Bump Stops / Slam Specialties Air Bags ???
Hello together,
what is a Integrated Bump Stops for Strength and Durability in my air bags from slam specialties ??? What does that mean ?? Thanks a lot Achim |
#2 | |
Re: What is a Integrated Bump Stops / Slam Specialties Air Bags ???
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
#3 | |
Does that mean that i dont need the original bump stop....for example i do have a camaro subframe in my pickup with the above mentioned air bags. At the moment i havent installed the original bump stop of the camaro. So when i drop the pickup on the ground, the air bag itself is the limited part, i mean the air bag itself is the bump stop.... What do u think about that , is that working for a long time....or do i definitly need a separate bump stop for my suspension... Thanks Cu achim |
I would guess to be safe, you should also run an external bumpstop. One that could handle the weight of the front end. I imagine the bumpstop inside the bag can only handle so much weight...
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
Hello
does anbody know the email address of slam specialties ?? Thanks Achim |
