oil pressue question
If i unplug my oil pressure wire from the sending unit and the gauge stays pegged all the way to the highest it means the sending unit is bad right??? And then one more question. Right next to the oil pressure sending unit by the distributor is a little 2 pronged can, what is this for???? When i have mine plugged in and i turn the truck off it stays running!!
Re: oil pressue question
I would think it would mean your gauge is bad. I don't know about the can.
79 C-20 Scottsdale 350/400 3:73 gears 9 leafs and a headache rack (I speak English, thank you) |
Ok thanks, that can comes off the same thing the oil pressure sending unit does.
Posted via Mobile Device |
Moderator
![]() Join Date: Oct 2008
1987?
The truck is a 85 K10, but its not the original engine and the numbers on the front ps of the block aren't there, so not sure what year the engine is.
