01-14-2012, 04:05 PM | #1 |
GoatLube Experss
crew cab short bed
I know this question get's ask'd alot but I'm gonna ask again any way, I search my self for a few hour's but with the crapy internet we have here make's it hard.
I am look'n for some GOOD link's about convert'n a 1 ton to short bed, specificly where to take the maesurements. or at least some advice on how to find em myself with out it show 7364 thread's unrelated to my search. Also curious if the Suburban tank will fit after the frame is short'nd.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
01-14-2012, 04:56 PM | #2 |
Re: crew cab short bed
I would think if you could not find them you could sit the shortbed on the long bed frame with the wheels and wheel wells in the bed aligned and measure what would need to be taken out dont forget to leave a gap for between the cab and bed. I know I have seen the measurements in a couple of the build threads
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
01-14-2012, 05:10 PM | #3 |
GoatLube Experss
I know it's 14 out'a the front and I recently read where on a 1 ton it's only 3 off the back, I'm curious where every start's the first cut line.
that's a good idea though, I could just set the bed on and mark it from there. Thanks.
01-14-2012, 09:03 PM | #4 |
Here is the best write up I have seen. http://67-72chevytrucks.com/vboard/s...d.php?t=460030
It looks like the center of the gas tank hangers is the best spot to start, from all the build threads I have seen.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-14-2012, 10:57 PM | #5 |
There are 3 different suburban tanks.
28 gallon, 32 gallon, and a 40 gallon. The 40 gallon won't fit in a stock height or lower short bed. Not enough room behind the axle. On cutting the frame, cut behind the very front bed mount bolt holes. That way, most of the holes should line up. You can figure out how much off the rear by sitting the bed on. On my CCSB, the PO cut too much off the back. I would leave as much as possible. If its going to be a 4x4 you could also move the rear axle forward 14" and cut all the difference off of the back. I think if you plan on a lowered 2wd the frame would be in the way of the axle using this method. Guess you could always notch the frame. Posted via Mobile Device
CHEVY ONLY |
01-15-2012, 03:15 AM | #6 | |
Maybe someone has done this and can school us. With a 1 ton at least. Posted via Mobile Device |
01-15-2012, 03:36 AM | #7 |
My buddy scotts62 did it on his 93 crew.
The frames are way different on those though, same principal. http://67-72chevytrucks.com/vboard/s...=369443&page=5 Posted via Mobile Device
CHEVY ONLY |
01-15-2012, 04:45 AM | #8 | |
GoatLube Experss
mine is 2WD and will ride about 3" off the ground. the link's Getto and Joe post'd will help me out. one thing I did read recently is on 1/2 and 3/4 tons ya take 6" off the rear but on 1ton's only 3". we'll see soon as I get home !
01-15-2012, 04:48 AM | #9 |
So your gonna shortbed your red dually?
CHEVY ONLY |
01-15-2012, 08:45 AM | #10 |
GoatLube Experss
yes, My girl friend found a good bed last week. a little rust where the fender need's to be cut for the dually.
I should be home in May or June for good so I'll be able to finaly do every thing to the truck. the bed and every thing to bag it is set'n there wait'n on me. you think a 32 gallon Suburban will fit OK ?
01-15-2012, 01:36 PM | #11 | |
01-15-2012, 05:07 PM | #12 | |
Yeah, I put a 32 gallon in my CCSB. I used the tank crossmembers from a Burb, but you can use the truck rear crossmember and fab a front one. It makes it a b***h to get to the rear bed bolts with the bumper, hitch, and tank in there The 28 and 32 are tge same width and depth, the 32 is deeper. !!! Posted via Mobile Device
CHEVY ONLY |
01-16-2012, 08:55 AM | #13 |
GoatLube Experss
thank's, ya My girl freind was glad to hear it also. I told her I'd be home in 12 month's,,,,,,,,,,,,,,,,,, 21 months ago.
