01-14-2012, 07:24 PM | #1 |
Hood Bolts??
I need help with the size of the bolts that hold the hood to the hood hinges. Thank you for the help
1958 Chevy Apache Stepside 1955 BBW Fleetside |
01-14-2012, 11:44 PM | #2 |
Re: Hood Bolts??
Just a heads up i posted the same question on the stovebolt page il let you know if anything comes up
01-15-2012, 04:58 AM | #3 |
Re: Hood Bolts??
ok thank you
01-15-2012, 02:47 PM | #4 |
Re: Hood Bolts??
You both realize that they are special sholdered bolts correct? You can't use just regular bolts. You might just want to pick up a set from Classic truck parts of America.
http://www.classicparts.com/1947-54-...ctinfo/38-525/ Good luck Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
01-15-2012, 03:37 PM | #5 |
Re: Hood Bolts??
Its an american thread and although they are shoulder bolts, function wise they do not need to be. I used over the counter s.s. bolts with 2 size s.s. washers and it looks and functions just fine.
current project; 1950 GMC "Junk Yard Dawg" http://67-72chevytrucks.com/vboard/s...d.php?t=635960 ___________________________________________ SOLD to "ONEBADFIVEFIVE" http://67-72chevytrucks.com/vboard/s...d.php?t=436406 |
01-15-2012, 06:51 PM | #6 |
Re: Hood Bolts??
hes the link from the stovebolt page
http://www.stovebolt.com/ubbthreads/...gonew=1#UNREAD |
01-15-2012, 08:35 PM | #7 |
Re: Hood Bolts??
Gee guess I got lucky, in 85 mine were pretty crusty so I just used standard grade 5 hex bolts and washers. They worked for 15 years as a dd. I think the original intent of the shoulder bolts with the knurled backs was to eliminate the need for lock washers on the assembly line.
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
01-15-2012, 11:51 PM | #8 |
Re: Hood Bolts??
yes its just a locking bolt shoulder bolts ,,i use regual 9/16 bolts with lock washers and a washer also never had a problem ,,i went stainless too ,or grab some fender bolts same size from a junk yard ..lol
04-16-2012, 05:41 PM | #9 |
Re: Hood Bolts??
what about the ones on the hood ? not the hinge to body side...
a regular bolt is too sloppy,right? talking about a 51 hood.. |
