Desert Dweller
New window regulators
I just stripped out my right window crank and the window regulator is also stripped from what looks like a set screw. Anyone know of a good replacement window regulator and handle? I looked at some at our last swap meet, but they looked so cheap and it would be nice to find something that will last awhile...
![]() Thanks! Posted via Mobile Device |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: New window regulators
I got them from classic parts a few years ago
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#3 | |
Desert Dweller
Senior Enthusiast
I found both NOS window and door latch regulators on Ebay a few years ago. They still turn up every now and then. Don't know how well the new replacement parts compare in quality.
![]() Join Date: Nov 2010
I have an extra drivers door laying around that has all the original window parts that are all free and move if interested.
They worked real well for me
Resistance is Futile
Hey Tony; I put one in the '66 on the drivers side and it was a new set-up. It's tight and works well. The only issue I have is that my original window crank doesnt fully engage the splines. I've had it fall off a couple times. I have a new crank but havent tried it to see if it fully engages the shaft better than the old one.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed Last edited by rbar; 01-15-2012 at 01:39 AM. Reason: .. |
I bought one from classic and it fell apart. They sent me a new one and it has worked so far, but I wasn't impressed by it, but it's better than nothing.
1963 Chevy stepside 327 1965 Chevy swb 383 1996 Mystic Mustang Cobra 2009 Pontiac G8 GXP 415hp/415tq 6speed |
tHE replacement stuff is cheap. I replaced mine on th e64 and never was able to keep them tight on the spline. Very poor quailty. NOS if you can find them.IMO I have orignal on my 66 and they never ever fall off.\
Good luck
Why can't I find it until the last place looked? 65 Longbed 283 three on the tree. 66 Longbed 292 three on the tree.Pennys A/C Trucks made in USA Buy a much as you can, Made in the USA |
Guys if you buy the replacement units, drill the center of the splined shaft, tap it with threads, drill a hole in the handle center, counter sink it slightly and use a bevel head screw, all mopars were this way, had a friend do the same on his truck somes years back and has never gotten loose yet. Also line the splined shaft with a small pisece of aluminum foil to take out the slop of the replacement handles.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
#12 | |
#13 |
Desert Dweller
Thanks guys.
I think I will try to locate a good used oem unit if I can... Since it's the passenger side, I might have a better chance at finding a decent one. I found a NOS on eBay, but I can't afford $94 right now. ![]() ![]() Posted via Mobile Device |
#14 | |
Desert Dweller
Thanks ![]() . Posted via Mobile Device |
#15 |
Rollin' Old Skool
i believe member Alan (Alan's Classic) installed an aftermarket regulator on his, but i'm not sure where he got it....i had to get one for my driver's door, but i went with a good used one from Tony @ http://4-5-6chevytrucks.com/index.html
_____________________________________________ Phillip My Build threads: 1966 Chevy C-10 "Black Betty" shortbed, fleetside, BBW, 327 V8/ Powerglide (under construction) http://67-72chevytrucks.com/vboard/s...ighlight=betty 1997 Chevy Tahoe, 2dr/2wd, mild custom (Daily driver) http://67-72chevytrucks.com/vboard/s...d.php?t=601142 Pics: '66 C-10 https://flic.kr/s/aHsjHWD4h9 '97 Tahoe https://flic.kr/s/aHsjGZ7wKP '93 C-1500 https://flic.kr/s/aHskxdpdnQ '88 S-10 Blazer https://flic.kr/s/aHsjYGx4Md Previous Rides: 1993 Chevy S-10 ext. cab, 4.3L, 4/5 drop (Sold) 1993 Chevy C-1500 short/step Retro-Rod (Sold) 1988 S-10 Blazer 2dr/2wd mild custom (Sold) |
#16 |
Wow i completely didnt notice you needed the passenger side haha sorry i do have window parts for a passenger as well
