01-14-2012, 08:34 PM | #1 |
Rear end off center
My rear end sits off center slightly, maybe 1/4". It's enough that my tire will rub on hard turns (the tires really fill up the wheel wells). If I could get it centered perfectly, it would not rub anymore. What does it take to center it? Just loosen the u-bolts on the axle and adjust the track bar?
Oh, I have a 67 Stepside with trailing arms. Thanks!
67 Stepside Atomic Orange Fastburn 385 TH350 The wheels are fronts are 255-45-18 with 5" bs. 18x8 wheel rears are 295-45-20 with 5" bs. 20x10 wheel (barely fit) Budget: A method for going broke methodically. You only live once! |
01-15-2012, 12:25 AM | #2 |
67-72 parts collector,…
Re: Rear end off center
You need an adjustable track bar (panhard bar).
Many aftermarket companies make them. Look at ECE (www.earlyclassic.com)
01-15-2012, 12:26 AM | #3 |
NICE truck,... by the way!
01-15-2012, 12:50 PM | #4 |
Your truck will do exactly what you're saying with a lowered rear and a stock panhard bar. As mentioned earlier, the Early Classic track bar kit will do wonders for your truck. Inexpensive, too.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
01-15-2012, 05:47 PM | #5 |
Thanks all! I kept the panhard bar that was on it when I bought it. I'm thinking it is aftermarket since it looks adjustable on the end.
