Old 01-14-2012, 08:48 PM   #1
SRVBLUES64
350 radiator hose
I recently bought a champion radiator from ebay I have made my trip to auto zone for the top and bottom rad hoses they were not even close, have a 350 in my 66 chevy truck. has anybody been through this before? or better yet dose any body have part #s for both the bottom and top hoses and where I can get them? Thanks for any help Jeff
SRVBLUES64 is offline   Reply With Quote
Old 01-14-2012, 10:19 PM   #2
Rich 5150 69
Rich 5150 69's Avatar
Re: 350 radiator hose
Just went thru the same thing, napa has the bottom hose, can`t find the molded hose for the top yet, LMC might have it as there site says so, its the same for 64 to 72 V8 I`m assuming your talking of, one word of caution, Champion supplied the rad cap with your radiator, mine would not release the pressure blue out my heater core, changed my cap out with another 13 pound cap all is good.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 01-14-2012, 11:10 PM   #3
SRVBLUES64
Thanks for the advice on the cap and hose
Old 01-14-2012, 11:21 PM   #4
tomfg
On my 64 with original radiator, and with a 1978 Chevy
350, I used Napa hoses....
upper NBHFF284
lower NBH7165
I believe the upper is a flex hose that fit as is,
and the lower was a molded hose
that I may have had to shorten a little.
tomfg is offline   Reply With Quote
Old 01-14-2012, 11:29 PM   #5
SRVBLUES64
Thanks Ill head to nappa Monday
Old 01-15-2012, 02:21 AM   #6
Rich 5150 69
One other tip, the original top radiator hold down bracket with the rubbers will not fit, I used two lenghts of 5/16 vaccum tubing sipped under the bracket front to rear, as long as the bracket is not rubbing the top tank you good to go...
Old 01-15-2012, 06:45 AM   #7
purebred
I believe I used a 1 1/2 inch X 25 inch flex for the top hose on my Chevy. Fit good
purebred is offline   Reply With Quote
Old 01-15-2012, 11:46 AM   #8
towersddg9
towersddg9's Avatar
I used the upper steel tube, had to cut it down a few inches using the forward hole for the engine mount. I went to AutoZone and matched hoses up, the lower I had to cut from both ends that part number is 70558 Dayco (short pump) I peeled the decal off the top hose so don't have that I will try and find the reciept and post that P# had to cut a couple inches off it as well
towersddg9 is offline   Reply With Quote
