01-14-2012, 10:20 PM | #1 |
Speedo calibration?
So I put in the new speedo cable in my 64 c10, 350/350 stock gauges. The speedo is off, what do I need to calibrate it to read the right speed. I have L78 whitewalls all around. Not sure how tall they are. Thanks for any input
Posted via Mobile Device |
01-15-2012, 12:23 AM | #2 |
Resistance is Futile
Re: Speedo calibration?
My '66 is the same. It's reading about ten mph fast. I believe you need to change the gears in the trans or get some type of adapter set-up. I havent done it hopped, so I'm not exactly sure.
Or just keep getting different size back tires until it reads right!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-15-2012, 02:45 AM | #3 |
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-15-2012, 10:19 AM | #4 |
Senior Car Nut
first figure out how much off your speedo is. you need to compare your actual speed to your indicated speed. there are several ways to do this: the old fashion way by timing how fast you traverse a known distance (typically a measured mile); using a calculator as suggested above (you need a tachometer for this method), or; use a GPS (or GPS App on a smart phone)
Then, on the side of the transmission where the cable attaches is a gear housing, take the cable off and remove the housing, which holds the driven gear. that gear will be colored and have a tooth count on it. finally, call these guys and tell them what you have: http://www.transmissioncenter.net/sp...n_______va.htm
Larry Last edited by fleetsidelarry; 01-15-2012 at 10:31 AM. |
01-15-2012, 04:53 PM | #5 |
I'll have to look into this too. Mines a little off.
Name: Rich Current Ride: 1964 C-10 Short Fleetside Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe Past GM Trucks: 1959 GMC short stepside 1968 GMC short stepside-4x4 1973 Chevy short stepside 1989 Chevy short fleetside-reg cab 1993 Chevy short fleetside-Xcab 2002 Chevy short fleetside-Xcab Save the dinosaurs, use synthetic oil. |
01-15-2012, 05:02 PM | #6 |
That's exactly what my speedo looks when I'm on the fwy!
01-15-2012, 10:13 PM | #7 |
Senior Car Nut
actually, Rich, that looks about right for a 700r4/3.73. what do you have?
Larry |
01-15-2012, 11:32 PM | #8 | |
If I was actually going that fast my truck would probably look like a satellite re-entering the atmosphere, flaming parts flying all over the place.
01-16-2012, 09:22 AM | #9 | |
Senior Car Nut
just guessing on tire size, but 70 is about right if your truck has a 3.73. if the vehicle the tranny came out of had a 2.73 (or maybe a 3.08, depending on original tire size) you would be seeing that sort of difference. you and hopped up may have to swap out both speedo gears, (driven AND drive)
Larry |
01-16-2012, 10:57 AM | #10 |
.........looks like my dash, too. 3k rpm.
01-16-2012, 03:37 PM | #11 |
wtf! now my speedo started to click and stays between 50-60. and my odometer just stopped working completely!
