Old 01-15-2012, 12:41 AM   #1
68steppsidee
Smile got a Question???
Has anyone ever notched a stock cross member to bring the lower control arms up farther from the ground... If not on these trucks on anything... Is it crazy??? any input thanks!!
68steppsidee is offline   Reply With Quote
Old 01-15-2012, 04:08 AM   #2
andrewmp6
Re: got a Question???
I know they section or pancake the crossmember or z the frame.But have you looked at a dropmember? It bolts in a 87 back truck besides welded in the notches for the rack and pinion does the same job as both with a lot less work.
andrewmp6 is offline   Reply With Quote
Old 01-15-2012, 05:29 AM   #3
oldspowered67C10
Yes, people have done it and it works. Keep in mind that you're supposed to move up the steering components(steering box and idler arm) an equal amount as well to avoid bump steer.
oldspowered67C10 is offline   Reply With Quote
Old 01-15-2012, 01:33 PM   #4
SCOTI
SCOTI's Avatar
Notching or pancaking the xmember is a way to gain drop or clearance on the front suspension. Like 'oldspowered67' mentioned, it is a compromise because it possibly takes the bumpsteer & makes it worse.
NoLimit Engineering makes a bolt-in R&P kit that can eliminate the issue....
http://www.67-72chevytrucks.com/vboa...d.php?t=465423
Originally Posted by andrewmp6
.....have you looked at a dropmember? It bolts in a 87 back truck besides welded in the notches for the rack and pinion does the same job as both with a lot less work.
Don't forget, PB is also finishing up on a version that does not require the steering notches. It doesn't get as low as his current 'Dropmembers' but offers the same improvement in geometry, clearance, & benefits of R&P steering.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-15-2012, 05:58 PM   #5
oldspowered67C10
Speaking of bump steer, has anyone done any measurements on how bad bump steer was on these trucks from the factory?
Old 01-15-2012, 09:12 PM   #6
68steppsidee
yeah i know about the dropmember just looking for more clearance and it to be cheaper.. how bad is it to move the idler arm and steering box
Old 01-15-2012, 09:43 PM   #7
broey
Square
broey's Avatar
I have seen a few on these trucks in person. and the owners all say the same thing, it drives exactly like it did before, as long as you dont go any further than a 1.5 inch pancake.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 01-15-2012, 09:45 PM   #8
jimmydean
jimmydean's Avatar
I can't wait to see Nate's mild dropmember, even though I will still be running the extreme drop myself.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-16-2012, 02:16 AM   #9
andrewmp6
A dropmember ain't cheap but its well worth it,You get rack and pinion the wheels are centered in the wheel wells and its narrowed just enough you can tuck any wheel size you could want.Or you want cheaper scotts hot rod shop on here has a bolt in ifs that will lay frame.here http://www.scottshotrods.com/6387clip.asp
Old 01-16-2012, 02:49 AM   #10
broey
Square
broey's Avatar
here is a link on pancakes that has been floating around the forums for a while.
click here
Old 01-18-2012, 07:22 PM   #11
68steppsidee
thanks everyone gives me alot to thank about
