Old 01-15-2012, 01:07 AM   #1
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Ground Wire?
Under the truck a couple of days ago re-installing the drivers lower seat belt bolt and I noticed a braided wire (looked like the material in braided hoses so I'm guessing it's braided wire?) coming from the cab to the frame. It was only a couple of inches long so I assume it is my cab-frame ground.
It looked like it got snagged on something at one point and it pretty frayed around a cut in it. I checked LMC and Classic Parts for "ground wire" and I cannot find anything on it. I can get regular wire (any gauge) easily but I bet if GM used braided wire there is a reason for it.
Is there a "ground kit" or something that I can get that would include all of the ground straps for my truck (77 c10)?
I think there is the
cab-frame
battery-frame
engine-frame
but I'm not sure how many others there are. I would like to replace all of the grounds just to be safe because if one is bad I figure the others are probably in the same shape.
Any help is appreciated, Thanks
Michael
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
