Old 04-26-2003, 08:56 AM   #1
messed up c-10
RHCP afficianado
messed up c-10's Avatar
electric fan setups
You guys with electric fans. Did you use a direct fit setup like this or another setup?
http://www.jegs.com/cgi-bin/ncommerc...90&prmenbr=361
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 04-26-2003, 09:18 AM   #2
bigd65
bigd65's Avatar
i just got 2 from a HONDA ACCORD and made the brackets. they are 13". what you need to look for is that they will flush mount on the radiator and then line the edge that touches the radiator with say vacuum hose or something that will prevent it from rubbibg through, i used the vacuum hose. i just split it all the way down and put it on the lip that touches the radiator
2004 Silverado Crewcab
1972 Chevy Monte Carlo
2017 Chevy Tahoe
bigd65 is offline   Reply With Quote
Old 04-26-2003, 03:29 PM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs down
600 BUX ,WOW!
I hope it's gold plated !!!
I just have 1 from a chevy corsica i'm not shure how big it is but it keeps it cool even with the a/c on in summer in so. Fla. and i only paid 20 bux for it.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 04-26-2003, 07:52 PM   #4
TODDS 72
Not the nightly winner
TODDS 72's Avatar
i got 2 from 2 dogde carravans,fits perfect,these have the brackets built into them just drill 3 holes and there mounted
72C10SWB BLUE 350/350
86K10LWB BLUE 5.7 700r4 7.5' fisher plow
93S10XCAB4X4 BLUE 4.3 4L60e
69gmc c10 v8 3 on the tree yellow 72k10 swb 350 3 on the tree green
86k15 swb5.0L 4spd brown
TODDS 72 is offline   Reply With Quote
Old 04-26-2003, 09:42 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
For $600 I had all the paint stripped of BADBOW down to the metal.
Here is my conversion page. Now that I have a house, I need to do some garage cleaning. :p BAD BOW may get the fans installed in May.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 04-27-2003, 08:43 AM   #6
Marks 85
Color By Krylon
Marks 85's Avatar
What did you guys use for a temp relay to turm them on with?
I have a duel one off of a caravan but I havent installed them because I dont want them on all the time.
Marks 85 is offline   Reply With Quote
Old 04-27-2003, 08:49 AM   #7
silvereagle1770
well i havent put them on yet but i have checked the fit and you can take the fans off a 1990 grand prix they fit great fills up the whole space of the rad
79 4x4 short box
silvereagle1770 is offline   Reply With Quote
Old 04-27-2003, 10:57 AM   #8
CustomChevy
Switching to electric is not that difficult. You need only pick the configuration you want. (ie 1- 16" fan, 2- 12" fans, etc) Wiring is fairly simple, I would recommend placing a relay in the system , especially if you have a/c. you can choose 2 ways to mount the fans, either by using thru-core rods or by fabricating some brackets to mount to the outer bracket of the radiator.
other than that, when wiring, double check to see that the fan is actually pulling air in and not blowing air out. when wiring the system, if positive/negative are reversed, this can happen, though some fans, will only work one way.
also choose what temp switch to use. you can use a variable or static type. your choice....
good luck!
CustomChevy is offline   Reply With Quote
Old 04-27-2003, 12:32 PM   #9
gldevall
gldevall's Avatar
All I did was wire them to an on/off toggle switch.
Gary -1986 SWB: lowered 4/6, SOLD!!!
-Best 1/4 mile: 14.51 @ 91.01 MPH
-2001 Pewter Tahoe, billet grill, Corsa Sport Cat-back, K&N FIPK SOLD!!!
-2004 Z-71 Extended cab with a flowmaster, BDS 6.5", 3" BL, 35x12.5x18 Trail Grapplers on Pro-Comp 18x9 wheels
gldevall is offline   Reply With Quote
Old 04-27-2003, 08:39 PM   #10
82BlackBeast
what do you guys think about these.. http://www.jegs.com/cgi-bin/ncommerc...49&prmenbr=361 ?? This is what I was looking at getting.
Matt
'82 Chevy SWB
82BlackBeast is offline   Reply With Quote
Old 04-27-2003, 09:36 PM   #11
LOHRTBT
BeWarE tHe eViL CrAnkTOe!
LOHRTBT's Avatar
Do a search on Electric fans...it will bring up lots of options. Personally I love my dual Haydens and the hayden temp sensor. Lifetime warranty from O reilly and was under 170 total! all new
~Dave~
You can call me Mike, Mike Oxlong
- 1986 Chevy SWB - Stock for now
- 1986 Chevy Custom SWB *Stolen 6/26/05*
- 1985 Chevy SWB SOLD
- 1999 T/A Some mods
www.cardomain.com/id/ramairdave
AIM Screenname - Jester84
LOHRTBT is offline   Reply With Quote
Old 04-28-2003, 11:50 AM   #12
rockman20
"The dude abides"
rockman20's Avatar
Not on a truck, but this is the setup I have on my 69 Cutlass.
Aluminum radiator. This is the big BeCool radiator you can purchase through Jegs. Nice setup. On this setup I have a dual 11" electric fans. The fan that is closest to the upper radiator hose is my primary fan. This fan is setup with a 195* sensor mounted in the intake. That wire runs down to a relay I have mounted on the core support. That relay is active only when the key is on.
My second fan is also controlled by a thermal sensor but this one is an adjustable one that has the probe in the radiator. I have this one setup at something like 225 or something like that. I don't really remember. The adjustable sensor is also a built in relay and this is mounted to the core as well.
Powering them, I have a dual post battery. I ran a thick starter wire off the side post positive and that runs down and then branches into 3 different wires. 2 of these wires go straight to the relays. The other wire runs over to my MSD 6AL ignition box. This assures me that the products needing power are getting everything they can get rather then running through the rest of the cars wiring first.
With this setup, my primary fan never kicks on unless I am idling for long periods of time. As long as the temps are around in the 70's. When the temps hit 90 here a while back, the primary fan kicked on more often, but still would run for about a minute or two and then shut off for about 5 minutes and then kick back on. The second fan has never had to come on yet. Only time that fan has ran is when I was first setting the system up and wanted to adjust that sender.
Before I would switch to electric on my truck, I would want to make sure of a few things. 1) How big my alternator is. These fans do suck some energy especially if two are running. 2) I would make sure my radiator is up to par or I would upgrade to aluminum.
In my case, I would setup the system the same way, but I would also set it up so that the fans are running all the time with the A/C on. I would probably also install a interior switch to overide the sending units so if I am towing something heavy or working the engine hard, I have the power to keep the fans on no matter what.
RockMan
1993 Chevy Silverado C3500 1 ton dually
1994 Honda Civic
1969 Oldsmobile Cutlass S
1953 IH Farmall Super M
New to the fleet:
1992 Subaru Loyal
rockman20 is offline   Reply With Quote
