measuring drive shaft length
What's the correct way to measure for a new drive shaft? I have installed the 283 & 700r4 in my 63 and now need to have a drive shaft made.
Thanks |
"Where were you in '62?"
![]() Join Date: Jul 2004
Me and my dad made mine for my '62.
![]() ![]() Looky here ![]() http://www.hotrodhotline.com/md/html...aft_basics.php
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN ![]() ![]() ![]() ![]() ![]() ![]() ![]() "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
Re: measuring drive shaft length
Dont forget to back the yoke out 3/4-1" out of the transmission before you measure to allow for suspension travel-otherwise it will eat up your seal.
When I put a 700r4 in my 64 I just measured the 350 turbo and the 700r4 and had my driveshaft shortened the difference. I fiqured the driveshaft worked on the 350 so cut down to fit the 700 it still should work.
100% gearhead
Measure from the flat suface of the rear yoke that (middle of u-joint) to the transmission tailshaft and subtractg 3/4". Everybody else nailed it though.
Imperial Kustom LLC Meridian Idaho. I never stopped playing with cars, they just got bigger. |
you could measure it a dozen different ways, but the bottom line is leave about 3/4 inch exposed at the tailstock as summerj suggests above for suspension movement of the rear end. If you get it too close, something, probably the trans will break. A truck service company did mine, balanced it and never had a problem driving it as a daily driver. Don't forget to address the electronic torque converter lockup and TV cable issues with the 700r4 or it won't last long.
