Old 01-15-2012, 05:30 PM   #1
scottveazie
Rear end ratios....What can I really change mine to?
Hey all, I've got 4.57:1 in my '65 C20, which needless to say, is too low for my taste. What gearset can a actually just swap into mine? Can I use ones out of a C10? Ideally, I'd like to go to 3.73, but I do not want to change the whole axle, just change the gearset in the diff. Thanks!
scottveazie is offline   Reply With Quote
Old 01-15-2012, 09:28 PM   #2
65Guy
Re: Rear end ratios....What can I really change mine to?
well with a gear that short you problly have a series 4 carrier which is the part that the ring gear bolts to. the lowest you can go with a 4 series is 3.73. if you want to go lower you will have to change the carrier. and im pretty shure any thing from a 65 all the way to a 87 if its truck 12 bolt it will fit, and if it is all stock you might consider blowing it all apart for a full rebuild. Bearings and seals.
65Guy is offline   Reply With Quote
Old 01-16-2012, 12:21 AM   #3
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Is you 3/4 ton got a 12 bolt? I thought it would be an Dana 60 or something like that
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 01-16-2012, 12:26 AM   #4
Captainfab
60-66 Nut
What you have is the Eaton HO52 differential. The 4.57 gears are probably the most common gears in those differentials. There are no aftermarket gears available for those. The tallest gears that were available for those differentials were 4.11's. I know you said you didn't want to change the whole differential, but that is the only way you are going to get 3.73's. I would recommend going with a '73 and up 14 bolt. They are a very tough differential, can be found with 3.73's, and parts are easily found and not expensive. Parts for the HO52's are getting harder to find, and when you do they are $$$$$$.
One other option would be if you could find a Dana 60 in a '67-'72 C20. That would be a bolt in, in your truck, and better gears available.
Didn't you buy a set of 14 bolt trailing arm mounts from me a while back?
Old 02-17-2012, 12:08 AM   #5
ozzyman
ozzyman's Avatar
Scottveazie - Hoping your subscribed to this thread because your PM inbox is full and I can't respond to your last PM about the axle perches.
ozzyman is offline   Reply With Quote
Old 02-17-2012, 12:54 AM   #6
scottveazie
Oops...finally cleared it out. I will probably go the Dana 60 route with my truck.
Grandpa's 1965 Chevrolet C20 in the family since new
