Red
'72 hot tub
We got hammered the other day with thunderstorms. After the rain stopped I was going to Autozone for something or the other and noticed that I had about 8 " of water in the front part of the bed of my truck. I noticed that these trucks(or at least mine) , don't have any drain holes in the front part of the bed like my '89 Silverado did. Have any of ya'll drilled a hole in the front corners of the bed to allow water to drain out?
Mike
'72 Cheyenne LWB 350/350 "The sun don't shine on the same dog's ass all the time." - Catfish Hunter (commenting on why he was not able to pitch another perfect game). |
67-72 Addict!
My 70' has drain holes that were in it.
Jim 1970 C/10 Fleetside w/Ghost Flames Lowered 4.5" front and 4" rear (Raked) 355/350 Turbo w/shift kit 10" Redneck Performance Verter w/2500 stall Hooker Super Comps part#2808-1 Performer RPM Air-Gap 12 Bolt w/3:73 gears- Eaton Posi Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads |
When I tore out the rotten wood from my short stepside and welded in a metal bed floor from a newer box, I made sure to leave the drain holes. Even when I got it rhino lined, I had them keep the drain holes open. It's one of the areas you always see rusted out on fleetsides. I think it's a good idea. Be sure to keep your door drain holes open too. good luck, Scott
Silence is golden, duct tape is silver. - Scott |
Mike,
My 71 and 68 beds both have drain holes. They are actually not in the bed floor but are in the panel closest to the cab. They are in the corners of the bed at the bottom close to the sides. In fact they are not really round holes but are like a quarter inch size rounded on the top and flat towards the bottom the bottom. I have seen the replacement panels for the beds and the ones I have seen do come with these already there.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
mine is the same as hutches the only problem for me though is keeping them unclogged as my parking spot is under a tree
Krazy Texan My Trucks are made with Wrenches not Chop Sticks 1967 GMC 3/4 ton "Johnny Cash" 1990 v1500 suburban 1967 Ford f100 Swb 4x4 "green bean" GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO |
Red
Hutch,
I can't orient myself to your pic. I went out and took this pic of the inside bed looking at the front drivers side corner. Is this the area where your pic is taken? Mike
Red
For some reason I con't get the pic to work!
Mike
newly minted old timer
i have been looking at the thick plastic sheeting i have and then looking at the truck bed.... hum... redneck portable swimming pool.. just might do that soon
____________________________________________ 72 c20 longhorn 65k org miles and counting! 69 k10 Suburban |
I have holes drilled but I did them small so sometimes they get clogged up. But it is a good way to prevent rust.
Mike,
The bed is off of the truck. The picture was taken looking from between the cab and bed on the outside towards the back on the passenger side. Here is one from the inside the bed looking forward towards the drivers side. The hole is sort of hard to see due to the colors. Have fun
I got drain holes but they arent exactly stock and they werent drilled. Its not a little drain hole either its about 1 inch across and in the middle of the bed.
1972 GMC SWB, 305 powered 1980 diesel VW pickup, Needs a Heart Transplant 1997 Toyota Taco The Second Amendment is in place incase they ignore the others. |
my 72 longbed has em in the bed. round holes. like 4 or 5 near the front. 2 or 3 closest to the front bed panel in the metal... a small and a big hole on either side also.
70 longbed 496/th400/Ford 9" |
#13 |
Red
Hutch,
thanks again. I went out and looked and someone had put what looked like tub and tile caulk in those holes sometime ago. I'm not sure WHY though. Thanks to ya'll , my bed will drain once again! Seriously, Thanks, Mike
#14 |
my 70 has drain holes.....
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
#15 |
My 67 doesnt. Hope my new bed will though....
'67 LWB C-10, 406 cid th350, dunno what rear end Looking to rent a house in Puget Sound area, anyone have one? |
#16 |
Saving 1 truck at a time!
My '67 fleetside has them...they are tough to find...more of a slot on the front outer edge of the box near the cab. Like Hutch has shown in his pic. I used a stainless steel dental tool to clean them out. I just drilled 1" holes in the stepside wood floor...it was about shot anyway! Solarus...check again with that dental pick and you will find them.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
#17 |
![]() Join Date: Dec 2001
PO punched 6 holes in the front of my bed with a hammer and chisel, then twisted the chisel sideways to enlarge them. No, they are not all the same size or evenly spaced, but I will admit the bed drains rather nicely.
1942 Master Deluxe 1969 C/10 1985 Blazer CUCV 1987 Jimmy 2004 Tahoe 2005 Silverado 1500 2005 Silverado 3500 |
#18 |
if you don't put in drain holes, nature will do it for you
#19 |
![]() Join Date: Dec 2002
drilled 2 holes 1/2 diameter in front of bed about 8" from corners....works Ok...but no matter what size holes.. if there is only a couple of treeleaves floating around ; they will find their way to cover the drain holes!!!!!!!!!!!
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
#20 |
I'm hopeing the new box I'm pickup up on Friday is gonna be a good one
#21 |
My 69 C10 has a nice set of drain holes. There about 4" long by about 2.5" tall. They are the result of rust. But hey, at least my bed dont hold water.
1969 C-10 w/91,000 on original 307 and still purrs like a kitten. 1972 Chyanne w/ original 350, but soon will have a 502crate motor. Need a LWB for it though. |
#22 |
why do you need a lwb for a 502? that sounds tight...
