Bedliner on door panels...
Mine looked like garbage, so I sprayed them with bedliner. The truck is about the get rebuilt , but 'til then this looks pretty good for $9. Pretty easy, figured I'd share.........
THE DEVIL MADE ME DO IT! |
Re: Bedliner on door panels...
It looks like it came out like black dye. Did it leave or add any texture?
John 82 Chevy Silverado 350ci/TH350 ![]() |
It does add a slight texture. Kind of like a grip-taped skateboard, with paint on it. Really, perfect for the door panels.
![]() Join Date: May 2009
Looks good, I like it.
03 GMC Yukon XL 2500 Quadrasteer, wife`s DD 84 Chevy K30 CC SRW 55 Chevy 210 2dr post |
The One And Only !!!
That turned out purdy good !
What kind of prep did you do before spray'n ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! ![]() The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
![]() Join Date: Jul 2010
nice work
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
Damn now to decide between this or Krylon....Nice though, I like it it a lot
I wiped it with Acetone, then hit it with Scotchbrite....then Acetone again. The first cleaning with Acetone is so you don't grind the crud in with the Scothbrite.
Now why couldnt you do the same thing with a dash pad? Trim up the cracks, fill them in with some sort of plastic body filler or such, then spray with bed liner. Couldnt you then use a something like Plastikote with color to go over the bed liner?
#10 | |
78K & 79C Jimmys
plastic coat i've used would still scratch
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
@Motornut....I'm not sure about the temperature tolerances. I make it a habit to never go anywhere that the temp gets below freezing.....ever, no matter what
I used to you that stone chip gaurd stuff you would spray on the bottom half of you ext and down on the rockers panels when I built tweeters into the plastic pillars by the winshields. it gave a nice texture. I did the bedliner stuff on door panels before and in the heat it was very easy to scratch that stuff off
_________________________________ 62 Impala 70 C-10 LWB 71 K-10 SWB 85 C-10 LWB==SOLD 01 2500 HD Members Met......2003Silverado (Dave) |
#13 |
Looks good.
Just as an fyi for anyone else who wants to do this....the rustoleum is better for less texture. In my experience(which is many cans)the duplicolor spray bedliner is much more textured than the rustoleum.
1995 Suburban K2500 454.....off road & towing 1999 Astro, work van 2006 Silverado 2wd 5.3 w/4.5" lift and 33s |
#14 |
I was going to line-x my doorpanels but the grit is just so big... Thats never coming off...
Posted via Mobile Device |
#15 | |
78K & 79C Jimmys
that may blow some peoples minds,and rads lol
#16 | |
GoatLube Experss
![]() Join Date: Oct 2009
grant'd I've had these here for right a year, the Line-X is peel'n off in sheet's. when it come's off it look's like they prep'd em good , it's just once a spot does break loose and the air can get to it spread's quickly.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#17 |
Motornut... is it soft rubbery or hard.... so do you still like it so far..
#18 | |
78K & 79C Jimmys
#19 |
that looks like something i wanna try.my door panels look all faded and ugly
#20 |
I love spray on bedliner stuff. You can hide all sorts of flaws with that stuff. I figure if it can hide nasty flaws on the truck that good, It ought to be safe enough and worth the try to spray the wife with...
#21 |
What brand did you use..
