Old 01-15-2012, 09:38 PM   #1
Nemesis 10
Nemesis 10's Avatar
1955 chevy cab ?
I have a chance to buy a 55 Chevy truck cab , in pretty good condition, I would like to mount this on my 1981 Chevy 1/2 ton short box step side, I would like to use the 81 box and complete drive train, Does any one have any input on this project, or any problems I could incounter.
Nemesis 10 is offline   Reply With Quote
Old 01-15-2012, 10:35 PM   #2
Maximus
Maximus's Avatar
Re: 1955 chevy cab ?
I don't know much about the project you are thinking about tackling but the first thing I would do is measure the frame widths. I know alot of late frames are too wide for the drop-down steps these trucks have...
thats all the insight I can give for now.. hah... good luck!!
Maximus is offline   Reply With Quote
Old 01-16-2012, 01:05 AM   #3
meter swinger
meter swinger's Avatar
is this a 1st series 55 or 2nd series cab? (advance design i.e. five window or task force i.e. Wrap around or small window?
Do you have the 55 front sheet metal? ( fenders hood etc.)
Guys have done a task force body on a c-10 frame. But you would be better off with a complete 55 truck. Not to mention its a lot of work and your front tire clearances will be tight.
Having owned a couple square bodies, and a couple 50's trucks i would just get another c-10 cab and build that.
It would be a lot easier and your chances of actually getting it back on the road are much better.
meter swinger is offline   Reply With Quote
Old 01-16-2012, 01:18 AM   #4
OrrieG
OrrieG's Avatar
I would look at some the the build threads that used 73-87 frames for TF. The biggest problem is that the frame is wider and runs thru the TF step area, or gets lifted really high. That also pushs the wheels and tires outside of the bodly line (sometimes refered to as the Hot Wheels look). I believe the bed floor needs lifted to to clear the frame rise over the rear axles. And you have to deal with the radiator support/front clip and front bumper mounting. Without the full truck you will have to locate all the small pieces needed to attach everything together. It can be done, search here and online to find examples so you know what the final look will be and how much work it will take to get there.
OrrieG is offline   Reply With Quote
