Old 01-15-2012, 10:53 PM   #1
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
What did you get done 1/15/12 edition
i am still fooling with getting parts for mine while we are doing body work... You?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 01-15-2012, 11:45 PM   #2
trout
Re: What did you get done 1/15/12 edition
move all my parts around and getting ready to take them to the scrape n dump
Edited by staff
trout is offline   Reply With Quote
Old 01-16-2012, 12:30 AM   #3
TJBrown
TJBrown's Avatar
Start out Saturday at the U-Pull it again. Got a rim for a spare that i never had. Radiator Over Flow Tank, Window Washer Tank with Motor. and the Stainless Trim piece at the bottom of the door. Installed the Two tanks and work on glassing the speaker box's since it was getting late.
Sunday started with a trip to the parts house. new Back Brakes, new Wheel Cylinders, New Axle Bearings, and New Axle Seals. Rented the Axles puller and Slide Hammer. Took Pretty much all day with the mishaps along the way. All is back together now.
85 Silverado SWB
TJBrown is offline   Reply With Quote
Old 01-16-2012, 12:38 AM   #4
83GMCK2500
Tore the dash down for the second time this month (two weeks ago cleaned and refurb'd cluster; all new bulbs, swapped C-H Temp gauge for one with numbers and L-H Oil Press gauge for numbered). Today I was focused on the radio. I had the analog AM/FM deck that hasn't worked for about 9 months now. Now I've got an oem digital am/fm/cass deck out of an '88 Suburban. Had to install and route the extra power harness that the new radio required, in doing so I had to add a terminal to my headlamp switch connector. I ended up having to pry the connector off of the switch due to a partially melted connector body. At some point there was a short in the highbeams and the connector melted, gonna have to tear the dash apart again soon and replace it.
Any chance I can buy the terminal ends that are in that connector? I would like to replace a couple of mine.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 01-16-2012, 01:38 AM   #5
JRANGER
JRANGER's Avatar
Installed new Speedo cable to fix jumpy speedometer and trans leak...Speedo is good, trans is still leaking so ordered new gear housing... Replaced all burnt dash lights with Blue LED 8MM lights I made....Now im going to clean this trans and try some suggestions on finding the leak..AKA clean and baby powder it until the gar housing comes in
JRANGER is offline   Reply With Quote
Old 01-16-2012, 01:56 AM   #6
Low84
Low84's Avatar
Got my truck getting the cab corner replaced to make it rust free, and deposited money on the card to order the lsx swap parts.
Low84 is offline   Reply With Quote
Old 01-16-2012, 02:57 AM   #7
pat386
misshape grape
pat386's Avatar
Saturday, my brother and I went on a trip to Daytona Beach and jacksonville to hit up 3 junkyards. Empty handed in Daytona. Purchased a spare ashtray at one yard in Jax, and a wipermotor and a washer reservoir from an 86 at the other. Went there looking for seatbelts.
Also got my seat mounted down lower, to the floor. No stock brackets and no slider.
Since my seatbelts are 88+ and I want the correct ones in my 83, no clean ones, or any at the junkyards. Found a place who happens to be in Florida that repairs and builds seatbelts. Going to find out about having the pre 88 tongues put into my belts because mine are very clean.
Don't you just love rumors? I always find out stuff about myself that I had no idea I even did..
pat386 is offline   Reply With Quote
Old 01-16-2012, 04:15 AM   #8
Stepper86
Stepper86's Avatar
Started to replace my front end bushings,shocks. And decided to put on new brakepads while I was at it.
Was in a hurry when I picked up the parts and it was not until I was puting things back together I noticed that I forgot to buy the upper ball joints
Orderd a new exhaust system, true dual with cats, mufflers and hangers for 600$ now I need to decide if im going to keep the original manifolds or get a set of ramhorns.
Tom.______________________________________
The fleet:
2007 BMW 530xi M (daily driver)
1986 C-10 Stepside (project "my time")
1992 Corvette cab (summer time daily driver)
1969 Cadilac DeVille Cab ("it just need some paint")
Stepper86 is offline   Reply With Quote
Old 01-16-2012, 02:37 PM   #9
rfmaster
rfmaster's Avatar
1) Did not watch football - well, only the highlights late in the evening.
2) Finished all minor stuff on my freshly built (350) engine - re-routed EFI harness, installed new temp sending unit, tightened all bolts, etc. Engine (it was broken-in on the engine test stand) fired right away and after full warm up checked for leaks and loose stuff. None were to be found.
3) Went on several test drives which involved EFI tuning and more checking. Wow - throttle response is rather quick & snappy! Have to be careful with loud pedal!
4) Unfortunately, had to park it and spend quality time with OL to keep piece in the house.
Next weekend
More tuning is ahead as new engine has at least 50 more HP over the tired old mill! Sorry, no photos or videos - did not have the time as weather was closing in.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 01-16-2012, 06:56 PM   #10
cochino12
It followed me home?
cochino12's Avatar
Got the front end lowered on my new 84, I'm swapping the 10 bolt for a 12 so I didnt have enough time to finish the rear.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-16-2012, 07:21 PM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Looks good Adam. I love that redneck rake...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-16-2012, 11:19 PM   #12
Rollinsqrbdy
Rollinsqrbdy's Avatar
Well Ive been outta the game for awhile now. I just went and saw a 83 square swb and it has a factory 6.2 DIESEL. The guys selling it dirt, dirt cheap and just cant pass on it. So IM BACKKKKKKKKKKK, lol
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 01-16-2012, 11:22 PM   #13
craazy22
craazy22's Avatar
Got to build a stand for my cab, removed the bed and started cleaning up the frame
81 chevy stepside 6.0/t56 swap in progress....
81 chevy silverado k5 2wd 350 tpi and 700r4.. SOLD
07 chevy colorado "work truck" SOLD
02 chevy silverado z71 off road package
craazy22 is offline   Reply With Quote
Old 01-17-2012, 02:42 AM   #14
Kerlijah
Kerlijah's Avatar
Swapped out the battery in my girlfriend's mom's 79 stepside on friday, finally got the sucker runnin for the first time in like a year and a half! Still gotta work on some wiring, bleed the brakes, and clean in up a bunch before we can get it back on the road Then I was bored to death on saturday, so I convinced my girl to let me straight pipe her Durango, lol...all in all a good weekend =)
~Wooden Indian~
1979 C10 SWB, shaved bed rails, drip rails, tailgate handle. 350 w/ Comp cam, hydraulic lifters, Edelbrock Performer intake, Edelbrock 650 carb, Flowtech headers, Flowmaster 40s, turbo 350 w/stage 2 shift kit...so much fun!
Kerlijah is offline   Reply With Quote
Old 01-17-2012, 06:29 AM   #15
rcbildr
rcbildr's Avatar
Couldn't do anything but surf craigslist (kinda looking for a 6.2L diesel for my shortbed)...we got 6" of snow that day...and more the next and a little more after that and I found out that we will be getting more over the next couple days. All in all there is about 1 foot of snow on my back deck.
My Projects:
1960 GMC 1/2ton with 305 V6 (daily driver)
1963 Chevy 1/2ton 2wd...converting to 4x4
1967 Suburban 1/2ton 2wd
My Girlfriends Projects
1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver)
1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam
1978 Camaro Z28
rcbildr is offline   Reply With Quote
Old 01-17-2012, 06:43 AM   #16
MalibuSSwagon
Installed new MTC1 cam, lifter, double roller chain, and got the TPI lower manifold installed. Today I am going to get the fuel rail and wiring run.
MalibuSSwagon is offline   Reply With Quote
Old 01-17-2012, 08:23 AM   #17
ECU PIRATE
ECU PIRATE's Avatar
Picked up a new bed for the " Brown Hornet ". Traded a buddy of mine in the Marine Corps some old Camaro parts. Almost rust free but, 100% better than the one that is on the truck now
The Fleet........
68' Camaro - 1st car (restored & still have it)
09' VW Tiguan (Wife's Daily Driver)
14' VW Passat SE TSI (my personal)
14' Ford Edge Sport (Daily Work Vehicle)
73' SWB Stepside - 77K org. miles
74' LWB 454/TH400 - drive train transplant for my (Sold)
98' SWB C1500 W/T - shop truck (Sold)
90' GMC Sierra SLE short step - aka " Jezabelle " (Sold)
ECU PIRATE is offline   Reply With Quote
Old 01-17-2012, 10:32 AM   #18
paul66c10
paul66c10's Avatar
couple days late but got my porterbuilt dropmember and mmw flat plate arms for porterbuilts dropmember finally installed. picked up a complete 5.3 ls motor minus tranny to drop in next. Next step order the rear dropmember from porterbuilt.
1986 gmc shortbed (right now its rough) porterbuilt dropmember front mmw flat plate uppers and lowers, soon to have porterbuilt rear dropmember, painted cherry red rallies, flat green primer in the works with a gloss white roof, 92 civic dx daily beater, 01 z06 new toy
paul66c10 is offline   Reply With Quote
Old 01-17-2012, 11:45 AM   #19
GuZ
GuZ's Avatar
It's a good feeling getting a fresh new bed isn't it?? Just started working on mine. Got the old one off, new one is almost ready to go on!
Follow my build at:
http://67-72chevytrucks.com/vboard/s...d.php?t=503795
GuZ is offline   Reply With Quote
Old 01-17-2012, 11:57 AM   #20
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Removed some oxidation. Wax is up next.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 01-17-2012, 01:36 PM   #21
JRANGER
JRANGER's Avatar
HOw hard is it to remove the bed?
Old 01-17-2012, 02:06 PM   #22
GuZ
GuZ's Avatar
Jranger it's really simple. remove the tailights and tailight housing. Pull the harness out. Take a phillips screwdriver and pull the 3 screws from the fuel filler. Then you just remove the 8 bolts under the frame (4 towards the front of the bed, 4 towards the back)
Make sure you have some helping hands to lift the bed off! They can be really heavy towards the front where it meets the cab.
Old 01-17-2012, 02:08 PM   #23
JRANGER
JRANGER's Avatar
awesome!!! I may need to do that to repair my cab corners
Old 01-17-2012, 02:12 PM   #24
GuZ
GuZ's Avatar
that would def. be the time to do it. There is so much easy access to everything while the bed is off.
Old 01-17-2012, 02:35 PM   #25
JRANGER
JRANGER's Avatar
yeah, and i can remove some rust and etc a lil easier....Coat the frame
