![]() Join Date: Mar 2011
identifying front clip
Hey Everyone,
Im hoping someone can help me out with identifying the year model of my front clip. So i can buy drop spindles and a new rubber overhaul kit for the front end. Also any suggestions on what brand or where i should get the 2" drop spindles from?? It would be a big help. I can take more photos if needed . Thanks ![]() ![]() ![]()
Blake. Sydney Aus 56 Chev 3100 build - http://67-72chevytrucks.com/vboard/s...d.php?t=480363 LOW n LOUD ![]() |
Re: identifying front clip
More pics would help.
IMHO it looks more like a Chevelle than a Camaro or Nova. It could also be from something else like a Monte Carlo. Kim |
the upper a arms don't drop that much. I think camaro or 80s monty carlo
looks like my second gen camaro. what ever it is it has the tall spindles.
#5 | |
Kim |
Looks like a 74-81 camaro clip. As far as what year you will have to remove upper a arms and measure the outside diameter of bushing to find out.
I thought the only difference is the lower a arm bolts. the early used 7/16" and the later used a 1/2"
they do but it is a little farther back from where this one is grafted.Couldn't find one of mine so I swiped a couple. Hope Indian doesn't mind
I don't mind! I think those are a good tool to look at
I think I'd be more concerned with getting the stub and frame plated a lot better where they match up before worrying about rebuild pieces for the stub.
Better shots of the crossmember it's self rather than just shots of the brakes and A frame might help some of the guys pin down the model and year a lot closer. |
They are good angles, hope they help
#12 | |
#13 |
Thanks Guys, i know its a horrible clip install but that will all be fixed.
will get more photos tonight..
#14 |
Do you mean extra tall spindles to lift the truck? or just standard ?
#15 | |
Are the lug bolts 7/16 sae or metric or ???????????? That could also help with the year model. |
#16 |
![]() Join Date: Jan 2009
Took me a while to ID my camaro clip also, in the end I googled the casting number on the spindle and some other parts. ended up being a 79-81. and narrowed further by checking outer bearing diameter (80-81). Great start and good luck!
1949/1954 with LS swap-yeah! http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos |
