Old 01-16-2012, 11:09 AM   #1
Jake65
Cab Sound Deadening Question
Getting ready to get to work on the cab of the truck and got on the subject with dad about sound deadener. I'm going to run duals off the 292 and dump them out the bottom after the cab, will i need to put down some sound deadener to hear the radio and people talking. Advice would help.
Jake65 is offline   Reply With Quote
Old 01-16-2012, 11:17 AM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Cab Sound Deadening Question
I would recommend it based on my experience if you want a good noise level. I drove 100 miles in my '64 with NO sound deadner (or carpet) and I had a noise hangover when I got out. The muffs are right at the back of the cab. My '66 has turbos in roughly the same spot and it is fairly loud too. I can still hear the stereo!! Both trucks have V8's.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-16-2012, 11:37 AM   #3
Jake65
What brand would you recommend that is easy to apply and can be purchased on a budget.
Old 01-16-2012, 11:53 AM   #4
Jake65
What brand would you recommend that is easy to apply and is affordable on a budget.
Old 01-16-2012, 12:25 PM   #5
jimmydean
jimmydean's Avatar
I went with peel and seal from Home Depot. Comes in 25 foot rolls of 6" wide. I used about 3 rolls to do from behind the gas tank to the firewall. get a wooden roller from a stereo shop and it will get it nice and smooth. I used an industrial carpet pad over that, it's about 6mm thick, then carpet. My cab is so crazy quiet, it's like a brand new truck.
I also used a strip on the back side of my door panels, and some on the door skin. No rattles, dead quiet. At least until my stereo goes in
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 01-16-2012, 12:26 PM   #6
jimmydean
jimmydean's Avatar
If you have about $100 to spend, get some FatMat. It's a better product. But my whole floor with carpet was less than $100. I'm happy with it.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-16-2012, 12:35 PM   #7
Jake65
Thanks, i am not running any carpet in mine though, so would i just do everything up until the carpet pad. I am running a poly vinyl floor mat in it. Thanks i will definitely look into that.
Old 01-16-2012, 12:57 PM   #8
b2948kevin
b2948kevin's Avatar
You should take some time to read the information here:
http://www.sounddeadenershowdown.com/cgi-bin/index.cgi
This guy has done more research on sound deadening than anyone else I know combined. Also, don't buy the name brand sound deadening materials. It will run you into the poor house. There are materials that are just as good without the name brand that will suit your needs easily, if you do your research.
I did a soundproofing project a while ago on my Mercedes 300td. Below is the link.
http://www.peachparts.com/shopforum/...-84-300td.html
66 Chevy C10 Stepside LWB My Build Thread
75 Harley FLH
84 Mercedes 300TD Diesel Wagon
b2948kevin is offline   Reply With Quote
Old 01-16-2012, 12:58 PM   #9
protrash64
protrash64's Avatar
Ive used the peel and seal also. I havent done the whole floor so I cant say how well it works but it did cut down some resonance from under the cab.
Old 01-16-2012, 01:43 PM   #10
losthope
losthope's Avatar
I used EZCOOL sound deadner on my 54 ford,they are a Hamb vendor and alot of guys use and have had great results,super fast shipping.....it doesnt have peel and stick so you just use 3m spray adhesive. reasonable price also.the $32.50 40sq ft. roll did the whole bottom floor pan of my car so it would do a truck cab floor plus more no problem.....
if you scroll down on the main page theres also burn test video and also a customer that did a whole bunch of tests before and after on his car heres the link for the customer tests:
http://www.shanescitshed.com/cx2500/...nsulation.html
heres the link to the site:
http://www.lobucrod.com/
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 01-16-2012, 02:26 PM   #11
Jake65
Thanks, i will definitely look into everything you guys have told me and i will also relay this to my dad and see what he says. Are there any other areas i should cover with insulation other than the floor?
Old 01-16-2012, 05:29 PM   #12
Joemomma1
Joemomma1's Avatar
I just put down dynamat extreme. I haven't got it on the road so I cant say what difference it has made. You will always hear "this stuff is better then that and cheaper". Maybe it's the placebo effect I wanted but there is a reason everyone tries to compare to it.
Joemomma1 is offline   Reply With Quote
Old 01-16-2012, 09:24 PM   #13
Max1775
Max1775's Avatar
I'd do the back wall behind the seat. It'll really help.
Max1775 is offline   Reply With Quote
Old 01-17-2012, 01:38 AM   #14
Heater63
Heater63's Avatar
I agree with all above, and do floor and back wall. And make sure all weatherstripping is sealing tight. Lots of sound can come through the smallest of gaps.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 01-17-2012, 06:14 AM   #15
kevinc
kevinc's Avatar
Can you see the soundproofing if its on the back wall? How far up did you go with it? I would prefer it to be hidden. Can you post pictures of the inside of your cab?
Thank you,
Kevin C
1988 C1500 Regular Cab, Long Bed, 2WD.
kevinc is offline   Reply With Quote
Old 01-17-2012, 04:58 PM   #16
theastronaut
theastronaut's Avatar
Thank you,
Kevin C
I'm planning on doing some sort of hidden sound deadener on my '66. I want it to look stock with the floor painted under the seat. I'm thinking about using Lizzard Skin's Sound Control, and a homemade version of Lizzard Skin's ceramic heat control on the underside of the cab floor while I've got the cab off, and also spray the inside of the firewall and back of the cab panel. Lizzard Skin's Heat Control is sandable and paintable, so you can block it flat and spray it with primer/paint to hide it. You can buy ceramic air beads to mix in with normal paint/primer to make your own spray-on heat insulation and if you used something like PPG DP series you could prime and paint over it.
theastronaut is offline   Reply With Quote
Old 01-17-2012, 05:08 PM   #17
theastronaut
Here's a cab I sprayed with Lizzard Skin's Sound Control and Heat Control coatings, two coats each. It's a little over the thickness of two credit cards and has a nice texture. Like I posted before, it's sandable and paintable so it could be hidden under paint. It's also waterproof so it's safe to use it on the bottom of the cab.
It dries black.
Old 01-17-2012, 05:10 PM   #18
Jake65
I will definitey consider doing this when i check out the money situation, and i will definitely meake sure that it is sealed up nice and tight. I have yet to do that but if i do it then i would only go to the top of where the tank will go in the cab so its hidden by the seat.
Old 01-17-2012, 05:42 PM   #19
jimmydean
jimmydean's Avatar
Thank you,
Kevin C
I'm doing a rear section for my stereo, so you won't see anything. there are a ton of shots of my interior in my build thread.
You don't need to cover EVERYTHING, but things like the strip on the backside of the door panel keep the vibrations down. I also wrapped my doors in vinyl, so my doors are solid like a new truck with tight seals. No wind noise, no rattles.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 01-17-2012, 08:48 PM   #20
T2vigil
T2vigil's Avatar
THEASTRONAUT has some great photos. Thanks John. I am going with the Lizard Skin for the Sound Deadening and the cost is in line with other hushmat type products. There are alternatives with the ceramic coatings that I will look into.
T2vigil is offline   Reply With Quote
Old 01-17-2012, 10:04 PM   #21
theastronaut
Glad I could help!
