Power Steering Box Conversion
Anybody know if the 73-87 Outer tie rods will bolt to my 67 drum spindles? Will I have to shorten the lower section of the steering column? I wanna swap out my sloppy manual box for a p/s box to shorten lock to lock.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
Re: Power Steering Box Conversion
PM Bump
Just did more digging and it looks like I dont even need a new pitman. Now I just gotta see what it takes to connect it to the column.
I seem to recall some saying you will have to dimple the frame for the power steering gear to fit properly on the earlier manual steering trucks. I put a 75 box on my truck and it was a direct bolt on. Mine is a 72 with PS though.
Yeah, I know you either have to dimple the frame or add the plate up to early 68. My biggest concern was the nuts and blolts of it. Seems I can bolt it in if I use the P/S pitman arm but I would think I would at least want the P/S idler too. From what I've seen so far in my research, the rag joint is not a problem either.
I am a Referee of life.
When I did mine I used a later model box and swapped to a 68 PS pitman arm.I didn't change tie rod ends(they were new from the disc swap).I didn't need a new idler so I didn't replace it.Mines a 68 so I didn't have to do the dimple.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
