Old 01-16-2012, 01:36 PM   #1
csa daddy
csa daddy's Avatar
6 lug rotors for 79 spindles
i have changed the front crossmember an a arms an put drop spindles on my 64 short bed my question is can i get a set of six lug rotors to fit the newer spindle so i can keep the six lug rallies on my truck cause the 5 lug rallies are diff an i want matching wheels all the way around so i can use my camaro derby caps.
csa daddy is offline   Reply With Quote
Old 01-16-2012, 01:41 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: 6 lug rotors for 79 spindles
You can order them from anyplace that sells brake kits. They are for 1.25'' width applications and use the same bearings as the 5-lug rotors.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 01-16-2012, 01:49 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Here you go,...
http://www.performanceonline.com/FRO...10-TRUCK-8600/
Keith
Convert to disc brakes.
Old 01-16-2012, 02:29 PM   #4
csa daddy
csa daddy's Avatar
So I can order the 6 lug rotors from the truck shop at 75 each an they will work. Thanks for the link nothing else I will go with those. I was worried if the bearings were the same
Old 01-16-2012, 02:34 PM   #5
lolife99
lolife99's Avatar
Bearings are the same as long as you have 1-1/4" rotors now.
I have those rotors on my '69.
Keith
Old 01-16-2012, 02:45 PM   #6
Narxoleptic Customs
I have a 84 sub spindle and ordered mine from CPP.
Narxoleptic Customs is offline   Reply With Quote
Old 01-16-2012, 02:55 PM   #7
csa daddy
csa daddy's Avatar
Cool thanks everybody I low what I got to do an as long as its a 73 up style it should have the 1 1/4 rotors correct. As soon as I get to the shop I'm going to measure my rotors to be sure
Old 01-16-2012, 03:10 PM   #8
lolife99
lolife99's Avatar
All 71-72 rotors are 1-1/4" wide.
USUALLY,... the 73-80 rotors are all 1-1/4".
The 81-87 could have 1" (light duty) or 1-1/4" (HD) rotors.
Measure to make sure.
Keith
Old 01-16-2012, 04:23 PM   #9
csa daddy
csa daddy's Avatar
Cool thanks I will measure to be sure
