Old 04-26-2003, 03:37 PM   #1
72PicKuPmAn
Solid Cab mounts
I am restoring my 72 to be a play toy, I was wondering if anyone has used solid cab mounts. I was wondering what you used to make them.
'72 S/S Chevy- in progress
72PicKuPmAn is offline   Reply With Quote
Old 04-26-2003, 04:40 PM   #2
72addict
Over time they will rattle your truck loose. Spot welds and all.
1957 Cameo
72addict is offline   Reply With Quote
Old 04-26-2003, 10:33 PM   #3
jmanz69
Careful, they attack...
jmanz69's Avatar
You won't like them, you will break stuff and sh!t will fall apart/off. Not a good idea, these trucks have a lot of vibrations from the suspension, and it will all go straight to the cab and you. Will be very noisy inside too. Get some poly mounts and do that. You need some sort of dampening. Even the ply mounts have been b!tched about on this board for being harsh riding and noisy.
jmanz69 is offline   Reply With Quote
Old 04-27-2003, 12:33 AM   #4
71-longbed
Its Magically Delicious
71-longbed's Avatar
so instead of ploy can you get rubber mounts ....or is poly the only kinda made ??
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
Old 04-27-2003, 08:16 AM   #5
jmanz69
jmanz69's Avatar
You can get rubber mounts. They are also still made, and cheaper. Go that way, you will be happier.
Old 04-27-2003, 08:22 AM   #6
71-longbed
71-longbed's Avatar
thanks !!! any tips on the best way to install them ???
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Old 04-27-2003, 08:25 AM   #7
jmanz69
jmanz69's Avatar
Never installed them myself, but if you put up another post asking how to install them, you will get some help.
good luck.
Old 04-27-2003, 02:47 PM   #8
casey
casey's Avatar
you'll probably do the ones under the rad support as well. loosin all 6 of the mounts slightly so theres a little give there, then do one side at a time I used a 3' 2x4 on my floor jack to distribute the weight, put the jack under it firmly, then take out the bolts on the side your jacking, jack it alittle more to get out the mounts and put the new ones in, bolt it back up, but not real tight then do the other side, when your done make sure every thing is sitting right before you tightin all the mounts up, on mine I had to put in some thick washers on some to level the cab out cause it was alittle tweeked
casey is offline   Reply With Quote
