![]() ![]() Join Date: Jan 2011
Core Support / Cab mount questions
I have a 69 SWB step side. I am putting a 68 clip on it.
I have heard the front cab mounts and the front core support mounts are different for the two years. (67-68 vs. 69-72) My question is do I still need to use 69+ cab and core support mounts on my 68 clip setup? I just want to make sure everything lines up correctly. .. Ex. Fender to door, and hood alignment. The frame is a 69, .. I have heard the front mounting points are lower on the 69 frame horns (?) I actually have both 68 and 69 style core support mounts, both new .. which do I use? I have 69 style front cab mounts now .. do I need to change to 68 style? Thanks.
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
![]() Join Date: Mar 2000
Re: Core Support / Cab mount questions
You need to use 69-72 Rad. mounts. The difference is in the frame mounted rad. support brackets. On a 67-68 frames these brackets are flush with the top of frame on 69-72 frames these brackets are below the frame top and require a thicker mount. So if its a 67-68 ALWAYS use 67-68 radiator support mounts even if you put a 69-72 front clip on it, if its a 69-72 frame always use 69-72 mounts even when using a 67-68 front clip.
GMCPaul |
I appreciate it GMCPaul -
On the front cab mounts are the 67-68 different than 69+ ? With my 69 w/68 clip do I use 67-68 type or 69+ (thinking they're different?). Thanks Posted via Mobile Device
ALL 67-72 1/2ton 2wd cab mounts are the same, only the core support mounts differ on the 2wd 1/2ton.
All 67-72 3/4ton&1ton 2wd, 1/2ton up 4X4 cab mounts are the same. GMCPaul |
Thank you sir !
#6 | |
![]() Join Date: May 2010
Here's a picture of my bracket locations. |
I'll have to check mine. My truck is a 69 frame so it's possible the mounts might be in the 68 position. .. But, I have both style mounts (both sets are new) so I will just use the one I need and sell the other.
thanks for your help.
Glad I asked ! Looks like my frame is a late 68 too ??
I think you should ask GMCPaul to look at your picture and render a verdict based on the position of your brackets. Perhaps PM him and ask that he look at this thread again? I reread what he said in post #4. I THINK he's saying that only the 1/2 ton 2WDs changed in 69 and that the 3/4 tons (such as mine), 1 tons and 4X4s never changed. I assume that means the 3/4 ton, 1 tons and all 4X4s from 67-72 should use the 67/68 style mounts, and only the 69-72 1/2 tons take the newer style. It would be great if some 1/2 ton owners could post some pics of their core support brackets.
My core support brackets on my 70 and my 72 are flush with the top of the frame...
Looks like the 67-68 frame mounts are in fact different.
http://67-72chevytrucks.com/vboard/s...d.php?t=505169 The holes in the front rad mounts are smaller in this frame than on mine. Quoted from GMCPaul above "...if its a 69-72 frame always use 69-72 mounts even when using a 67-68 front clip." I think I need the 69+ rad support mounts. The 67-68 style are smaller in diameter as I recall. Makes sense..
