turn signal assembly removal
1970 c20 350 auto
My shifter has been hard to pull lately and last night I finally managed to snap it. I got the shift lever off and could just spray it with some wd40 and put in a new lever, but I want to take it apart and clean it so it won't happen again. I got the steering wheel off, now i need to get the turn signal assembly off. It seems I need to use a puller on the bracket holding the turn signal assembly in place? or is there some other trick? After that piece has been removed I assume I will be able to clearly see where the shift lever attaches and throughly clean it? Thank You
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
