01-16-2012, 08:19 PM | #1 |
over flow
finally got the over flow tank installed. racked my brain as to where to kinda hide it, so my father in law fabed this bracket and it fit snug here so we went with it... not too bad.
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
01-16-2012, 10:47 PM | #2 |
Re: over flow
outta the way, looks good
01-17-2012, 06:26 AM | #3 |
Re: over flow
did you change the radiator cap so the system will work properly
01-17-2012, 09:46 AM | #4 |
Re: over flow
Looks way better then where I put mine. I'm thinking a move is in my future!
01-17-2012, 10:38 AM | #5 |
Florida Edition
Re: over flow
Please expound on this for us Mr Downs.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
01-17-2012, 02:43 PM | #6 |
Re: over flow
meaning? with the cap on it it seems to be pulling water in and out like it should. Does it need a different cap than the one I have on it
01-17-2012, 03:16 PM | #7 |
Re: over flow
01-17-2012, 04:21 PM | #8 |
Re: over flow
there are different types rad caps the originals that open with pressure dont always allow for fluid to b returned to rad on cooldown// modern closed system caps work properly //autoparts store should have the right type for your use
01-17-2012, 11:49 PM | #9 |
Re: over flow
so should I get a cap that has not pressure release lever? I am confused. yest the line pulls antifreese from the radiator.....
01-18-2012, 12:58 AM | #10 |
Re: over flow
you want a cap that has two gaskets on it, flip the cap over and you will be able to tell. I also tend to stay away from those cheap plastic levers, it would suck if they were to break. Also I prefer to run the highest pressure cap I think I can do. Some auto stores have a pressure tester for your radiator, you can pick one up and see if you can run a higher pressure cap.
01-18-2012, 01:26 PM | #11 |
Re: over flow
thanks for the info
