72 bottom trim ?'s
so after getting the top trim on I was looking at the truck and since we are not painting it until next year I wanted to know if the botton trim wood grain can be pealed off... also do you guys know if the botton trim is all adhesive or is it actually clipped on to the bottom like the top..
any ideas on how to either remove the wood trim stuff or paint the middle of the lower trim. I would rather take off the woog grain and polish the bottom trim like the top... I would consider removing all together if the trim is glued on..... let me know please.. ![]()
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Re: 72 bottom trim ?'s
In 1972 they use a little of both stick on and clips. Just get creative in removing the woodgrain. Then mask off and paint black. i would definitily put the trim back on. that truck would look funny without lower trim IMO
72 Cheyenne Super 80 Silverado Blazer 2wd |
now that you say it, I see how it would look weird with no bottom trim.... I think I will try to peal it off, if not sand it and paint.... I am hoping somebody has done this before and shares how the did remove it
I have used a good paint stripper before to remove the wood grain. Then you could ruff up the area a little, mask it and paint it black.
1971 Chevy SWB 4x4 1971 Chevy LWB 2003 Duramax |
I never tried it before but a good steamer takes wallpaper off real good, maybe it would work on the woodgrain
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
I will try a small spot first to see if it will work... then buff it and maybe paint it if it works
