Old 01-16-2012, 08:53 PM   #1
67whitley
1967 tubbed C-10 build questions *HELP*
I am building a custom 67 truck from scratch and need help. The front frame clip is a 70 camaro, the middle is truck frame, and the back is a four link clip all spliced and boxed. My question is I need to weld in a transmission cross member. Is the engine suppose to sit level or sit so many degrees tilted back? Also what angle does the pinion need to be? I need this info so I can custom make a drive shaft. Is a two piece with carrier bearing or one piece drive shaft better for drag racing? Need all the help i can get setting up the four link to make it hook. This is going to be a street/strip truck. Also how do you figure out what size rear gear and back tire you need? Im going to put a 402 bbc and turbo 400 in it for now. I cant remember what size tires is on it ill have to look. I know they are m/t sportsman series.
Thanks in advance Aaron
67whitley is offline   Reply With Quote
Old 01-16-2012, 11:48 PM   #2
SCOTI
SCOTI's Avatar
Re: 1967 tubbed C-10 build questions *HELP*
Level @ the carb/intake surface = 3° down @ the rear of the motor.
Internet research states the rear pinion for a typical street driven vehicle should be equal/opposite of the trans output yoke (3° down @ the trans output = 3° up @ the pinion). Hotrodders reality is this is tough to accomplish when things are changed vs stock so some compromise might be required. A high powered track type vehicle might need the pinion @ or below zero to counter the differential twisting forces depending on the quality of the rear suspension set-up.
For the track, a 1pc shaft is best.
Gearing & tire size for a track vehicle should be dictated by the engines expected RPM range. Check in w/these guys & start reading some build threads....
http://www.67-72chevytrucks.com/vboa...splay.php?f=60
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-17-2012, 12:51 PM   #3
67whitley
Thanks so much for taking the time to give me some advice! Keep the comments coming guys!
