Never Ending Projects
Picked up a '65 Panel
So I have been looking around for a Suburban or Pane from '64-'72 for a while. Not really serious unless the right deal came up. Then a couple weeks ago I sold our '00 Jeep Cherokee so I had funds to get more serious. Been looking for the last couple weeks. Went to check out a few and was disappointed. Rust buckets and bondo queens. I happened across this '65 Panel and checked it out yesterday. It has a minor dent in the lower rear drivers corner due to the lug nuts coming off and allowing the wheel to dismount from the drum. Outside of that, it truly has almost zero rust and is a good 3 footer paint job. Not perfect but the nicest I have had in an old truck.
I need to completely do the suspension as it still wears drums and most of the original parts. Add power steering and disc brakes, etc., etc. It currently has 22" wheels which are definitely going. Not sure what I am going to end up with but need to kind of decide so I know if I am going 5 lug or 6. Here are a few teasers that I got just as I got home and needed to get the trailer back. It was dark after that. Likely this weekend I will get some more. I am stoked with this. ![]() ![]() ![]() ![]()
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
Re: Picked up a '65 Panel
Nice! What are you thinking for stance and rim size?
Any inside pics?
Nope, only pics I have at the moment.
Not sure on wheel size and overall stance. I might do airbags on this project as I have wanted to do that on one for a while. Who knows?
Nice panel! Minus those wheels! Nice find and keep us posted
Posted via Mobile Device |
chevy only
![]() Join Date: Sep 2006
Very cool!!
CHEVY ONLY... Nothin Else ! |
Great looking truck. More pics please
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
meowMEOWmeowMEOW
the mini truck rims need to hit CL, but the truck itself is wicked.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
Sweet ride!!! Congrats!
#10 | |
That's where they will be headed. Luckily the PO gave me the slot mag wheels and tires so I can at least swap these off. As it is, the rears are hitting the wheel wells.
nice panel, dont look like it needs much but a wheel change and that driverside panel fixed and you would be go to go!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
It needs some engine tuning (think the timing is off), some little bits (rear door handle, door seals, interior, etc.) and a redo of the suspension.
In reality, a tune and putting the other wheels on and I likely could be driving it. That's my weekend plan but they are saying it's going to be raining all weekend. ![]()
#13 |
Cant wait to see pics with the slots on it!
#14 | |
#15 |
very nice ride. I maybe the only one that thinks this but the wheels are not that bad.
#16 |
Pretty sweet and if you need a rear bumper I have one just up the 5 from ya.
#17 | |
I am likely going to convert over to 5 lug but likely will got with a axle conversion kit, to keep the same housing. CPP, ECE and others offer them.
#18 |
Okay, got the wheels swapped off and some engine and inside pics. Did a little tune on the engine and it's running better but based on what is happening with the timing mark, I think the outer ring on the balancer has slipped. As I get more into it, I keep finding hokey stuff done. Need to sort out the under dash wiring.
Also while swapping wheels, of which had a mixed set of lug nuts, some mag style and some acorn style <slaps forehead>, it looks that the front coils were cut really short and the rear coils were heated. Why the heck people just can't spend the couple hundred dollars on a proper set of springs is beyond me... oh well. Here's some pics. ![]() ![]() ![]() 22" wheels, now on the ground ![]() ![]() Old slot mags ![]() ![]()
#19 |
Nice score and looks better with the slots.
#20 |
#21 |
Nice! And so much better with the slots.
#22 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
Yep, much better with the slots
![]() Very nice panel. I'd like to find one someday......like I need another vehicle ![]()
#23 |
![]() Join Date: Jan 2010
very nice score
#24 |
Looks tough with the slotted mags! Maybe a size or two smaller tire in the front would look killer also! Just a thought, but a whole lot classier with slots!
#25 |
Nice horn!!
Check the mounting on those seats, with the seat belts in them you want to make sure the floor will hold the seat in an accident. You don't want the bolts pulling through the floor and sending you into the steering wheel or worse.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
