01-16-2012, 11:12 PM | #1 |
Factory 17-18" wheels that fit our trucks??
Title was supposed to read 17-20"
Alright, after lowering my truck I am on the hunt to find some different wheels. I am looking for factory wheels that fit. Anyone know of the 20x8 steel wheels from dodge work? How about the new camaro 20's. Any luck there? Ram 1500 makes a nice set of wheels from the factory in chrome. Any luck there? Any help and ideas here is appreciated! Thank you. Anthony Posted via Mobile Device Last edited by el_guapo; 01-16-2012 at 11:34 PM. |
01-16-2012, 11:22 PM | #2 |
Re: Factory 17-18" wheels that fit our trucks??
Only thing I can think of is the new Jeep Wranglers (07-up)and the Jeep Grand Cherokees(03-up). Not sure about the center hub bore on them though.
1949 Five Window, 1973 Step Side, 2000 Z71 |
01-16-2012, 11:24 PM | #3 |
The Dodge truck wheels area Dodge/Ford bolt pattern.
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
01-16-2012, 11:40 PM | #4 |
BAD BOW-Silverado XST
Dodge/Ford are 5.5 patterns, I think. You need a 5X5. The last good GM set was 17" from a 94-96 Impala SS.
01-17-2012, 01:00 AM | #5 |
There is a thread here where a member put new camaro wheels on his truck, also seen one around town with new silverado wheels.
John 82 Chevy Silverado 350ci/TH350 |
01-17-2012, 01:50 AM | #6 |
Collector of Projects
They make wheel adapters that can space the wheels out and change the bolt pattern. Most modern wheels have a high offset and the 73-87 trucks need a mid to low offset. That being said the adapter solved both problems.
If you have a 5 lug setup, 1994-1996 Impala SS 17 rims fit, but are harder and harder to find... |
