C35 Crew Dually
trcuks got a shake
hey guys when im cruising at around 80km-90km my truck has a shake nothing crazy like when my hanger bearing had to be replaced but i can feel it in the seat.
any ideas? im thinking u joints?
If it aint square, I don't care. 84 C35 CC Dually Project log... http://67-72chevytrucks.com/vboard/s...d.php?t=414892 |
Robert Olson Transport
![]() Join Date: Oct 2002
Re: trcuks got a shake
an unbalanced driveshaft can do it so can u joints as long as youve eliminated the usual front end suspects and tires
C35 Crew Dually
all new front end compnents almost new tires and just ballanced all 6 tires and bought 4 rims for rear as mine were bent to F
I had the same thing with my truck and went crazy trying to figure it out. Wheels, Tires, axles , drive shaft. I had a lot of little gremlins in there. My seat would shake left to right at about 50 to 55. After beating my brains out on this the only thing I had not changed was the brake brums. To my amazment it got rid of about 60 percent of it. I still had a little tire issue and a little drive shaft issue. But finding the biggest problem helped to find the smaller problem. There may be more than one thing causing your shake. Just keep plugging at it . You will figgure it out.
Just a thought - transmission/motor mounts.
C35 Crew Dually
will looks at those too thanks.
Have you checked the steering stabilizer?
Rich My first truck!! ![]() |
C35 Crew Dually
what do you mean when you say that i think of the smaller shocks on 4*4's
mines 2WD.
The steering stabilizer is a horizontally mounted "shock absorber" on the drivers side in front of the axle. I think 2wd's had them...?
C35 Crew Dually
no 2WD doesnt (that i have ever seen)
What about spring bushings they will give a slight shake or vibration if they are wore out
Clint Youse Paris, MO 1984 Chevrolet 3+3 K30 with Cummins 1966 IH Scout has been a work in progress for 16 yrs |
i had vibration at the same speed as you (50 mph). after flipping the axle it corrected the angles and went away. you could check the pinion angles
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#13 |
C35 Crew Dually
hmmmm never thought of that how bad was your shake?
#14 |
not horrible but totally noticable to both the passengers and myself.
