I got a Dana 60 rear out of a Longhorn that was being parted. It has 3.54 gears in it.
What I need to know is will the rear end bolt into my 72 K-10 SWB? Are the perches the same width across? The Longhorn was a 71 or 72, with the 402....I still dont know why the guy parted it out...but I got the front clip and the rear for $500....probably a little high, but what the hay... I'd just measure it myself, but I'm aboard ship right now....and I didn't even think about the perch width until I read another post in this forum....Ideas? Thanks... ------------------ Pat Adams
Pat Adams |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
Will bolt right in, the pearches were the same distance apart. WES www.ClassicHeartbeat.com
------------------ Click (Here) to visit our on-line catolog. E-mail me WEHEPP@attbi.com 72 BB Chevy Blazer 72 BB Chevy Short Fleet 72 SB 3/4 Ton 4X4 72 SB 1/2 Ton SWB 4X4 70 BB Chevy Short Step 70 SB Chevy Short Fleet 69 SB Chevy Short Step 68 SB Chevy Short Step 68 BB GMC Long Fleet 67 GMC 1/2 ton Panel "Founder" Classic Heartbeat Pickup Club Olympia, Washington's "Home For Wayword Chevys" www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
do K10 also have 40" rear spring centers ? if so thne blazers, longhorns and all 4x4 have 40" ceters
Suburbans RULE!
My K10 Suburban has 40" centers on the rear 12 bolt.
------------------ 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, Scat crank, H-beam steel rods, KB Pistons, Speed-Pro Moly Rings, Clevite bearings, Speed-Pro High Volume oil-pump, Comp Cams 254H 4X4 Xtreme cam, SR Torquer 2.02/1.60 heads, Comp springs, Trick Flow pushrods, Comp Roller Rockers, Edelbrock Performer RPM intake, 3310 750cfm Holley, Summit HEI, MSD 6AL, Built TH350 Transcat Supper II shift kit 2000 RPM Stall, 4" Rough Country Lift....etc.
--Ben 71 GMC Suburban 4X4 The "Beast" 388 CID Stroker, TH350, NP205, 8-lug D44, 14BFF w/ Detroit, 4.10:1 gears, 4-Wheel Disks 4" Lift, 35" MT/R's. |
cool deal, so that means K10, K20 and blazers 4x4 and the 1 tons arer all 40" centers, nice, too bad C10 and C20 are 42.5" lol
Okay...so what you guy's are saying...even though this Longhorn is a C-20, the perch's are still 40 apart....like the K-10, and
K-20's? I'm mean...it's no great big deal anyway....perch's are movable...I was just wondering. Thanks for all the input! Patch
Pat Adams |
Jostrans68
seems to me someone wlse had a longhorn dana 60 and it is different. is this a 1/2 or 3/4. I think it was PICKMUP that had one and it was different.......my 2 cents
------------------ 68 c20 in progress 327 TH400 tach dash Disc Brakes and soon 3.90 rear gears.. have many new parts now just need the time..... Sound Familar
![]() former 67-72 now with a 96 silverado |
there are no 10 series longhorns, longhorns use the 40 centers, longhornmail or 69 longhorn recently measured on their longhorn leaves and confirmed this, all someone here has to do is go under their longhorn and m3easure real quick and see..
[This message has been edited by Fast68Chevy (edited March 26, 2002).] |
If the Longhorn is a two wheel drive you will have to re-weld perches. You didn't say in the first post, but most were and I think that would be especially true with 3.54 gears.
------------------ 70 GMC 3/4 ton Sierra Grande 402/TH400 72 Jimmy 4WD 4spd 4" & 35's 64 Corvette Coupe 68 Camaro 'vert TPI & TH700 69 Z/28 355 12.6's @110 72 Datsun 240Z-ol' reliable
Don't forget all longhorns are leaf suspensions. You would have to re-weld if you pulled one from a coil pickup and put it in a leaf (like a 4X).
------------------ Bowen '68 K20 fleet '69 K10 swb fleet '72 C10 lwb step
my 2¢ - t.i.o.l.i. Bowen 1968 K20 fleet 1969 K10 swb fleet 1972 K10 Suburban 1972 C10 lwb step 1992 K1500 'burb 1995 K2500 'burb 1997 C1500 'burb 1999 K1500 2000 K1500 'burb Why do I own so many Suburbans? |
And all longhorns were 2X. If it's a 4X longhorn, it's not original.
and all longhorns are leaf rear, they shuld all be 40" centers all except C10 and C20 pickups except for longhorn, where are longhornmail and 69longhorn at when you need em ? or someone with a true C20 or C30 longhorn ?
#13 |
Yes, the longhorn is 40" C to C on the springs.....its on a 30 series chassis. Mine is a 20 series truck,but still on a 30 series frame....69 longhorn.
http://community.webshots.com/user/hotrodhorn |
#14 |
longhorn axle will bolt into K10 then,
gear ratio in it has nothing to do with perches happy swapping Adam! [This message has been edited by Fast68Chevy (edited March 26, 2002).] |
#15 |
Okay...okay....I did say it was a 2 wheeler when I said it had a 402 in it....attention to details fellas!
![]() ------------------ Pat Adams
Pat Adams |
