Old 01-17-2012, 03:14 PM   #1
IOWNATRUCK
acceleration issue
my truck accelerates good when im accelerating slowly but if i push the gas to hard it bogs down a bit and then restores its power suddenly and goes, what could be the problem? i dont think its anything serious as the carb and all is new and was just calibrated, the engine has less than 2k on it as well, the fuel filter doesnt seem to be clogged, and it doesnt bog down at idle or in park or slow acceleration, bad gas? bad spark plugs? ideas?
Thanks.
IOWNATRUCK is offline   Reply With Quote
Old 01-17-2012, 03:54 PM   #2
IOWNATRUCK
Re: acceleration issue
also, it doesnt do any of these things in park which is making me think it cant be bad gas, or wires or plugs cause it would still do it in park right? any ideas!? choke is adjusting correctly, idles perfect. ha low gas maybe? idk anymore!
Old 01-17-2012, 04:47 PM   #3
JRANGER
JRANGER's Avatar
I would try to run some fuel system cleaner in it or maybe replace the fuel filter...Just sounds like its not getting enough gas or something is clogged
JRANGER is offline   Reply With Quote
