Old 01-17-2012, 05:16 PM   #1
bedfordia
Another fuel tank question
Howdy y'all
I am trying to pull the fuel tank out of my cab. I took the straps off from around the tank, thinking that would do it, still rock solid. do the two brackets that are under the tank bolted to the floor have to come out? If so , how do you get to the bolts that hold those down. Please help an old fool out!
bedfordia is offline   Reply With Quote
Old 01-17-2012, 09:34 PM   #2
yelmer
Re: Another fuel tank question
the tank should come out ,straps off ,fuel line disconnected, fill tube out . it might stuck on the tar pads
yelmer is offline   Reply With Quote
Old 01-17-2012, 09:47 PM   #3
cp_66_c20
cp_66_c20's Avatar
I had to remove mine too. After you remove the traps you need to pry on it a bit. The apoxey they origonaly used to hold the tank sticks to it from years of it being straped an dosent want to let it come out. The filler neck will need to be taken off too so that it comes out easier. I replaced the claps on the filler neck with worm clamps but thats up to you. Hope this helps
cp_66_c20 is offline   Reply With Quote
Old 01-17-2012, 10:18 PM   #4
bedfordia
Thanks Guys
I am always amazed at the knowledge that others have to share here. That's what makes this board great
Old 01-17-2012, 11:16 PM   #5
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Be careful with those straps.
Mine were loose, but still laying over the tank.
When I pulled on the tank, one swung up and slapped me in the face.
66 C20 Service Truck:
