Old 01-17-2012, 05:38 PM   #1
punk17
punk17's Avatar
Power brakes
Hey guys i putting power brakes on my 65 and I'm having trouble with brake pedal sticking when running at idle. Give it gas and it comes back up yes I have a bigger. Cam and I'm pulling about 10 lbs of vacum I put a canister on today and it helped but if you hold it down enough it stays down so though about doing away with booster. Though about hydroboost but ready to get it on the road.so my question does booster make big differnce. Thank yall for help.
punk17 is offline   Reply With Quote
Old 01-18-2012, 12:41 AM   #2
Captainfab
60-66 Nut
Re: Power brakes
Have you checked for the pushrod rubbing on something? Have you tried disconnecting the pushrod from the pedal, to see if it is perhaps an issue with the pedal pivot?
Old 01-18-2012, 01:09 PM   #3
tazattitude
tazattitude's Avatar
Re: Power brakes
I believe you are supposed to drill a hole about 1" down from the original due to the new angle of the booster/cylinder setup. I had read this somewhere.
TAZ
BUILDS
1966 GMC Suburban
1963 GMC Suburban Patina frame-on FOR Sale
1966 C10 Short Bed (2010-11)
Monthly Updates
2015 C10 Pics with my '72 Montego GT 429/521 build
1963 Pro Street C10 back halved. Frame off I did back in 1990
Pics / Video
tazattitude is offline   Reply With Quote
Old 01-18-2012, 01:57 PM   #4
punk17
punk17's Avatar
Re: Power brakes
THanks guys I moved pedal rod down already going to try a new spring on pedal I think maybe spring might be weak after 40 years of use.
