72 gauge cluster bulb replacement
so any tricks or tips... can the bulbs be replaced from the back easy with out taking cluster off.....
04 CHEVY LLY LS DURAMAX 4WD. MODS TO FOLLOW, EFI LIVE, BUILT TRANS, LBZ MP, LIFT PUMP SOLD 1972 chevy c10 |
Lemme show you something!!
Re: 72 gauge cluster bulb replacement
Yeah, you should be able to get to them with the cluster in place. It'll be a P.I.T.A. but possible. For as simple as it is to remove the cluster....it's a 10 minute job that will save you much more in the long run.
Nonetheless, here's a photo of where all the sockets are. Just remember "righty-tighty, lefty-loosy".
'67 CST-10 LWB ("Crusty") SOLD '67 GMC SWB ("Murdock") 2000 K1500 Suburban ("Betty") '95 BMW 325i ("Joy") |
I never tried it with the cluster installed.
However when I do have it out I test ALL the lights in the cluster so I don't have to take it apart right away again. I have one of those "jump box" things I got for a Christmas present a few years ago. It is essentially a lawn mower battery in a nice carrying box with two shorter jumper cables coming off the back. It doesn't have enough amps to start a cold, dead truck or car but with a pair of leads clamped in the jumper cables it is a nice way to get a clean (acid free or maybe I should say acid contained) 12V supply in the house when it is cold out so I can test things like cluster light bulbs. I just had the cluster out of my 98 Escort and went through all the bulbs. I knew one was out and ended up replacing another one. This isn't mine but simply a picture I just grabbed off the web:
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
The Older Generation
Unless you are a big guy or have trouble laying on your back in tight places it shouldn't be a problem to change them in place. Unfortunately you can't slide the seat back in an unmodified truck. I change bulbs all the time without removing the clusters. LockDoc
needs more $$$
Can you point out which ones illuminate the cluster and which ones are indicators? I bought new ones, but only for the illumination.
1970 2wd Blazer |
i am a big guy so laying may be more of a hassel. What does it take to remove the cluster
needs more $$$
Depends on how far you need it out. The bezel itself it just screws along the outter edge, but the speedo cable and oil gauge are connected, so depending on how much play you have you may have to disconnect those to get it out fully. I can't remember if the column needed to drop a little or not on mine, I don't think so, but the cover underneath it needs to come off.
1970 2wd Blazer |
#9 | |
The two in the lower left below the gas gauge are the brake and temp indicators. The two in the upper middle of the cluster are the turn signal indicators. And the single bulb above the speedo is the high beam indicator.
Curt 1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear |
needs more $$$
Thanks, camrycurt! That was perfect! Now, just gotta be able to blindly feel for these!
1970 2wd Blazer |
I just simply took my whole cluster out of my 72'. just take off the wiper/headlight knobs and unscrew the chrome thingys. then the bottom plate (2 big philipshead screws) then the rubber around the steering column(slide it up), then unscrew the cluster(6-8 screws), then i just unhooked my speedo cable to pull the cluster out completely. Heres a tip: use the correct 194 bulbs! i used bigger bulbs with a 194 base and it melted my printed circut and burnt some of the inside plastics. Not fun to smell burning plastic at 2AM when your plowing snow with no gauge light!
1947 Chev 3600, 454,th350,9"ford tubbed (Pop's ride) 1965 GMC 1000 305E V6, Powerglide. GONE ![]() 1972 GMC K-2500 350, 4 speed, 229,000 miles 1988 Chevrolet Caprice 9C1 Ex cop car, 350, 700r4. 1997 Ford F-350 4x4 XLT (The Hauler) 7.3 diesel. RUST NEVER SLEEPS |
#12 | |
As LockDoc said, it's actually pretty easy to get to them without removing the cluster. I've replaced them all a couple of times by just laying on my back on the driver's side floor with my legs and rear end sticking out of the open door. You can get your head up by the pedals and can see everything pretty clearly with a flashlight, and if you're not too big you should be able to snake one arm up behind the cluster and twist the sockets loose. Good luck! Functional dash lights are a good thing.
#13 |
thanks I need the light bad too....LOL
#14 | |
Those same 194s also light up your side marker lights on your pickup if so equipped.
#15 |
thanks all, for all the useful info...learned alot
